Thierry B.
Acheté en remplacement d'un Arcam Irdac, la différence est très nette : basses profondes, médiums bien présents, aigus...
Philippe A.
Bon outil
Philippe A.
pas mal
je l'utilise depuis qulques jours. appareil convivial et son très correct
Customers reviews - There are 21057 reviews.
GEORGIOS C.
Very useful and with surprisingly high value
Despite the different opinion in some comments, the design, the quality of the components and the construction and finally the sound performance are well above the asking price, even with the filter in place. The performance-price ratio is simply excellent and is mainly due to the quality of all the components used and the assembly which is well above the entry-level category. In terms of sound, expect an improvement across the spectrum, with a fuller and clearer low end, cleaner mids and highs and a more three-dimensional stereo image with clearer instrument contours. Perhaps the most important thing is that all of this happens without any noticeable penalty in dynamics which is the usual case even in some of the 2,000€ filters that I have tested. Highly recommend, especially at this price point. My system: Eversolo DMP-A8, AUDIOPHONICS HPA-DM750ET and AP300-S2503E (I prefer the later!!!), Focal Electra 1028 Be
Thomas M.
Gold Plated Reducer for Speaker Cable 2mm (Pair) These HP cable reducers allow you to insert a bare conductor to benefit from a 2mm banana plug. This particular format is especially useful for quick connection with clamp...
No deterioration in sound quality
I did not buy these reducers for my Electrocompaniet ECI-5, but I tried them with this integrated amp first. I did not perceive any deterioration in sound quality compared to a connection with the bare speaker cable (Supra Cables Classic 4.0).
There is only one drawback: when using a cable with a large cross-section (in my case, 4 square millimetres), the screw used to secure the end of the cable cannot be screwed completely into the plug. This renders the sleeves (which are only slightly elastic) unusable. Instead, I simply used gaffer tape in two different colours.
Frédéric G.
Excellent câble de modulation avec une bande passante qui semble très large. RQP au top.
Yves J.
nickel
envoie rapide et qualité au rendez vous .comme beaucoup j étais réticent le fait de branché deux paire d enceintes et perdre en qualité sonore .ben non tout va bien
MANUEL R.
Tubes corrects, sans plus
Utilisé dans un primanluna evo 400 et dac 100, tubes de qualité convenable. Timbre de qualité, plutôt neutre, ni trop en avant ni trop en arrière. Extension des aigus timides cependant et dynamique moyenne. Un jj 12au7 pin gold est moins neutre, mais plus musical, plus étendu dans l'aigu, avec un grave un peu plus gras mais surtout plus dynamique. Je dirais que la PSvane vaut la primaluna d'origine globalement, qui est assez bonne mais sonne un peu différemment. Pick your poison,)
Yves F.
BEATECHNIK X LHY AUDIO LPS-A6-MKII Linear Power Supply Module for Eversolo DMP-A6 GEN 2 220V Designed specifically for the Eversolo DMP-A6 GEN2 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end...
Pour remplacement d'une alim de DMP-A6 gen2 HS. Le remplacement est simple à réaliser pour tout bricoleur. Le niveau du son est peut-etre un peu plus "élevé" que sur l'alimentation native. Tres content de cet achat. Le son du DMP-A6 couplé a un Roksan K3 V2 + AE320 toujours aussi ouaaa.
Valentin A.
Bang for the buck
I already had an iFi Audio reclocker, Focusrite DAC with iFi Elite power supplies and Audioquest Diamond cables so I was a bit skeptical about this card. I was terribly wrong! This Elfidelity raised the sound quality on my PC by a big margin: more air, more details, more calmness, more bass and enhanced holographic sound. I'm getting dangerously close to the sound of a 30k Hi-Fi audio system.
Vladimir L.
Power Supply Filter Module for Raspberry Pi 5976µF This HAT module allows to filter a power supply to provide a clean electrical signal to a Raspberry Pi and a DAC, connected directly via GPIO. The filter integrates a series of...
Must have
An extraordinary upgrade for little money. Every Rpi must have it.
Jean-Marc S.
FOSI AUDIO V3-48V Stereo Class D Amplifier TPA3255 2x225W 4 Ohm The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a...
RPQ imbattable ?
Au delà de mes attentes, drive parfaitement de vieilles Bibliothèques d'un rendement de 86dB !
Marius M.
VIBORG XF203AG Female XLR Connector Pure Silver PTFE Ø11mm Red (Unit) Viborg's XM203AG is a premium XLR female connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
Viborg 203 AG XLR+NEI 1001 II
It offers a completely neutral sound in combination with the neotech NEI 1001 II pure silver cable. Fine highs, a weighty midrange and a perfectly clean bass, without harmonic distortions... It cleans the voice of mud, as well as the contrabass instruments as no copper cable can do. Also the signal to my REL subwoofer (powered by the amplifier) ​​is so clean that I can increase the volume without any traces of distortion or vibrations in the listening room, which I could not do with any copper interconnect cable... I recommend it together with any pure silver cable, regardless of whether the cable is round or rectangular wire.
P.S. I can't understand those who use copper connectors together with pure silver cables.
Fabrice L.
RAMM AUDIO S8 Interconnect Cable RCA OFHC Copper 1.5m This affordable, high-quality RAMM Audio S8 RCA-RCA modulation cable features single-stranded OFHC copper conductors. It also features several levels of shielding with aluminum...
Un cable qui a tout d'un grand?
Acheté par curiosité,et enthousiasmé de suite, pas de période de "rodage".
Avec ce RAMM AUDIO S8, on atteint un plaisir d'écoute renouvelé, grande neutralité, suivant bien la dynamique de la musique, ses inflexions, ses subtilités.
Belle image sonore tout à fait crédible.
La constituion Air Geometry du câble n'est pas qu'un argument marketing.
De plus la fabrication avec des connecteurs RCA (de petite taille d'ailleurs) est remarquable, il suffit de dévisser un capot de RCA pour s'en rendre compte.
Alors vu le rapport qualité/prix de ce câble, pourquoi s'échiner à réaliser ses propres câbles.
Vraiment ce RAMM concurrence les câbles à base de Mogami 2549,Sommercable Albedo,Canaré L-4E6S ou Grimm.
Ne possédant pas de câbles haut de gamme à des prix hors normes, je ne peux pas savoir si ce câble a tout d'un grand.
Peut être qu'un passionné équipé de ces câbles pourrait investir dans ce RAMM pour faire la comparaison?
Chiche.
Essai avec Préampli Advance Paris BX1-Ampli Tube EL 34 Yves Cochet AL2a-Enceintes Pier Audio Filante Tubular 21-Câbles HP RAMM Audio TA-15
PS:J'en profite pour féliciter Audiophonics pour la qualité de ses prestations constamment au top et sa pertinence à proposer des produits aussi divers et variés.Bravo!
gilles b.
OPA2210 Dual OPA DIP8 (Unit) This OPA2210 is a dual OPA mounted on DIP8. It is built on Texas Instrument's Super Beta precision complementary bipolar semiconductor...
Excellent rendu sonore dans mon contexte d'utilisation !
Il est très difficile de choisir des amplis opérationnels (OPA), selon l'endroit ou vous choisirez de mettre des opa, si pour exemple vous mettez un type d'opa dans une pré amplification d'un DAC ! ce même type d'opa n'aura pas du tout le même rendu (ou comportement) dans une pré amplification d'un ampli, donc il est toujours préférable (si c'est possible) de comparer plusieurs types d'opa pour se faire une idée de la viabilité.
Pour ma part j'ai voulu tenter les 2210 et j'ai bien fait !! car précédemment je venais d'acheter un paire de Burr Brown V7 Vivid (qualité garantie au RDV) que j'avais intégré dans mon ampli Poppulse T180 qui avait pris une belle évolution sonore puisqu'il était à l'origine équipé d'une paire d'opa LM49720, et de bien loin musicalement parlant les V7 Vivid atomisaient les LM49720, avec les V7 tout est à sa place, et l'aspect parfois brouillon sur des passages denses en instruments a disparu.
Ayant le besoin de récupérer les opa V7 Vivid que je voulais intégrer dans mon pré ampli, j'ai piqué tout simplement les V7 dans le T180 en attendant de trouver une paire d'opa a la hauteur de celui ci, et n'ayant pas les moyens d'investir dans une paire de V7, je me suis donc dirigé vers les opa 2210 qui me semblait être un bon compromis.
J'ai par la suite comparé les V7 avec les 2210 toujours à partir du T180, les 2210 s'en sortent relativement bien même si ils n'atteignent pas le niveau de transparence des V7, ils sont en tout cas bien plus précis que les LM49720 qui étaient montés à l'origine, en conclusion j'adopte les 2210 dans le Poppulse T180 qui garde son aspect dynamique et précis sans jamais surjouer dans aucun registre, les 2210 apportent de la sérénité au registre grave qui est rapide sans effet de trainage au contraire des LM49720 qui avaient tendance à marteler le grave avec certes un manque de délicatesse avec parfois une perte de vélocité déclenchant un effet de trainage fort désagréable.
J'ai lu à droite et à gauche sur le net, que certaines personnes disaient que les 2210 avaient tendance à trop appuyer et renforcer le registre grave, pour ma part les 2210 sont vifs et précis et ils ne dominent pas sur les registres médium et aigu, je les trouve très équilibrés, et sans coloration quelconque.
La totalité de ces écoutes comparatives ont été réalisé sur une paire d'enceintes Klipsch RF5 qui font dans la dentelle quand elles sont bien alimentées et accompagnées d'une excellente source, les filtres ont été totalement refait avec des condensateurs Mundorf en gamme Evo et Suprême, et elles m'ont permis de réaliser les bienfaits des 2210 dans le T180, je suis ravi du résultat, et je peux que les conseiller dans le cadre d'une utilisation dans une pré amplification.
Les 2210 a mon goût sont meilleurs que les opa 2134, les opa 1656 et certainement bien d'autres, et ainsi je considère qu'ils sont d'un bon rapport qualité.
Stereo Line Preamplifier OPA NE5532 This NE5532 based buffer preamplifier module with 50KAX2 potentiometer allows to buffer and preamplify a stereo signal in an autonomous and qualitative way.
Aurait pu être mieux !
Fonctionne très bien, facile à mettre en œuvre, un gros point noir, la grosse difficulté de le fixer, car aucun perçage n'est prévu, ou possible sur la carte PCB...
Cambon F.
Ajouté à mon ensemble Fosi Zd3+Za3 & Dynaudio EMIT II 10.
Après avoir essayé différentes combinaisons d'OpAmp ce petit FX est nettement plus avantageux, il efface le coté un peu aride de ma config et apporte le réglage de tonalité qui manquait
j'ai essayé les lampes d'origine mais j'avais commandé dès l'origine des remplaçantes qui offres pour un prix modeste encore un meilleur rendu / Merci Audiophonics, livraison rapide
SAVA M.
Good product
It's probably not the best board of its kind, but definitely worth the money. This board replaced a Matrix board about 10 times more expensive. Clearer sound, more detail, more air.
Didier C.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a...
bon produit difficile a utiliser car pas de notice en français
Aleksandr P.
Greate cables
They connect in my setup DAC Denafrips Venus with fully analogue amplifier Yamaha A-S2200. Perform excellent, deliver refined natural sound. I feel these cables are especially suitable for serious music (classical, jazz).
Aleksandr P.
NEOTECH STDCT-14 Hook-Up Wiring Multi-Strands UP-OCC PTFE 2mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Alexander P.
Perfect hook-up cable. In my DiY speakers initially I have done all internal wiring with silver plated OFC cable and a year later replace it with Neotech STDCT-20 for tweeter, STDCT-16 for midrange and STDCT-14 for bass circuits. Sound improvement was substantial. As I did speakers upgrade where binding posts and solder were replaced for higher grades at same time I can not say how much Neotech STDCT cables contributed in sound improvement but feel it was significant contribution.
Aleksandr P.
NEOTECH STDCT-20 Hook-Up Wiring Multi-Strands UP-OCC Copper PTFE 0.52mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Alexander P.
Aleksandr P.
Alexander P.
Very good solder. Easy to work, good laying down (cohesion) with copper, better then "ordinary" 4 pct sliver content solder. Definately positive effect on sound.
Daniel D.
câble secteur de très haut niveau
Câble secteur installé volontairement à un endroit stratégique de mon système à savoir du mur à la barette. Il arrose en aval la source et le préampli, mes blocs mono sont branchés en ligne directe et séparée en tête de tableau avec disjoncteur cryogénisé.
Que dire de ce câble ! En un seul mot... magnifique pour la première je suis scotché dès la première écoute.
Ce câble est rapide avec des attaques bien franches, sur les musiques rythmées on tape du pied, ça fait du bien.
La scène sonore est vraiment hors du commun avec une excellente profondeur et largeur et beaucoup d'air entre les instruments et/ou pupitres, Sur du Yello c'est un vrai festival... Il a immédiatement détroné mon câble antérieur avec un effet wahou immédiat!!!
Au niveau de la résolution c'est aussi de très haut niveau (sur le net certains le compare au DPS 4.1 de furutech que perso je ne connais pas).
Sur mon système il est monté avec une schuko ETI legato et une IEC oyade coo4. Dans cette configuration les timbres ne souffrent d'aucune coloration particulière mais cela dépend bien sûr du reste du câblage car en introduisant par exemple un câble furutech FP 3TS20 sur la source tout était trop chaud avec une perte évidente de musicalité alors que la scène sonore était encore un poil plus grande. Perso je privilégie la musicalité et tout cela n'est qu'une question d'association bien entendu. Le rendu en l'état est donc plutôt froid avec pour avantage de ne pas dénaturer les cordes de piano et guitares. Les cuivres sont scintillants mais sans excès, superbes. Avec mes électroniques le grave a de la densité, c'est ferme donc mais avec de la transparence ce qui est parfois incompatible sur d'autres montages. A noter qu'au tout début il y a de la stridence dans le médium/haut médium avec des basses en léger en retrait mais tout cela disparait vraiment très vite. Je n'en suis qu'à quelques heures de rodage et c'est déjà du tout bon. Je remercie l'acheteur Hongrois de ces commentaires car j'hésitais justement entre ce Néotech et l'Oyade vondita, à la lecture de son ressenti j'ai opté pour le Néotech. Attention, les fiches secteurs ont beaucoup d'importance avec des effets cumulés indéniables (3 Eti légato sur mon système mon fait nettement progressé sur la transparence/rapidité/musicalité). C'est toujours risqué en terme d'équilibre (chez moi trop de Furutech tue le Furutech) mais Je vais commander le même Néotech (en 4mm) pour ma source. Musicalement à tous,
DOUK AUDIO A5 Integrated Amplifier PFFB TPA3255 NE5532 2x120W 4 Ohm The Douk Audio A5 integrated amplifier is a small amplifier based on audiophile components with a singular aesthetic. It relies on a TPA3255 amplifier chip and OPA NE5532 to...
VRAIMENT MUSICAL...
On retrouve avec ce Douk Audio A5 une transparence typique des amplis de classe D, transparence que j'ai pu aussi trouver sur certains amplis à transistors ou à lampes valant autour des 2000 euros. A la sortie du carton, le petit Douk manque singulièrement de puissance bien qu'alimenté par un bon bloc 48V 10A! en fait après une trentaine d'heures de rodage, la puissance de sortie s'accroît quelque peu, mais en aucun cas on obtient les valeurs (très exagérées) indiquées par le constructeur. Il est vivement conseillé de remplacer les deux AOP d'origine par de meilleurs composants: l'AOP discret SX52B d'origine chinoise s'accouple parfaitement avec le DOUK A5 alors qu'il est incompatible avec mon Aiyima A07 ou le Douk A5 pro (allez comprendre!). On peut aussi, si on est un peu bricoleur, souder un petit condensateur MKP de 1 microF aux pates du condensateur chimique de 3300 microF manière de compenser un peu l'inductance parasite des chimiques. Avec les quelques modifications précitées, musicalement ce petit DOUK s'avère être une belle surprise: définition et transparence sont à-même de révéler tous les détails de vos fichiers audio avec pour revers de révéler aussi tous les défauts d'une prise de son à condition que votre DAC et vos enceintes en soient capables bien sûr. Les timbres sont d'une beau réalisme, sans maigreur comme je l'avais constaté avec mon Aiyima A07 MAX et sans grossissement non plus; les extinctions de notes très convaincantes, mais ce qui est le plus réjouissant c'est l'imagerie stereo, véritablement holographique avec une extension en profondeur fort appréciable, qui vous transporte littéralement dans la salle d'enregistrement. Sur un plan purement pratique, les leds lumineuses vert/rouge/bleu qui éclairent les circuits sont parfaitement inutiles (on peut heureusement les désélectionner) et la vitre facilitant les changement des ampli ops ne tient que par miracle (bande adhésive), là aussi on aurait pu se passer d'un tel gadget. En résumé: un petit ampli peu coûteux, éminemment musical, qui mérite un bon DAC et des câbles de modulation soignés.
Frederic g.
à écouter sans réserve
Ces tubes sont à la hauteur de leur réputation. Dès la mise en place, au lieu de tube JJ, plus d'ouverture et la petite verdeur du haut médium a disparu pour faire place à du détail et de la matière.
Le reste du spectre n'est pas en reste avec un aigu plein, qui file haut et sans d'agressivité et des basses informatives, dynamiques et dénuées d'embonpoint.
Michael P.
Banana plug
Absolute sound.
Aleksandr P.
WBT-0708Ag Speaker Terminals SIlver (Set x4) Coming from the latest generation of development by WBT, the Nextgen 0708Ag speaker terminals are fitted with silver conductors.
Alexander P.
Great binding posts. After replacement of ordinary brass terminals for WBT-0708Ag in my DIY speakers (full 3-way speakers built in line with high standards for listening mainly classical music) sound improved significantly. More details, transparency, more natural sound.
Lionel B.
FURUTECH HF-X-NCF HDMI 2.1 Cable 8K/60Hz 4K/120Hz 48Gbps HDCP2.3 eARC HDR10+ Silver Plated OFC Copper 1.5m Furutech offers with the HF-X-NCF a high-end HDMI cable, compatible with 4K/8K 48Gbit/s and incorporating the know-how and attention to detail of the brand.
Câble monté entre le TV et le pré-ampli home cinéma. Son dense, plein et dynamique avec beaucoup de détails et de finesse. A conseiller sans réserve.
Aleksandar K.
SHANLING SCD1.3 CD SACD Player DAC AKM4499EX + AKM4191EQ Black With its SCD1.3, Shanling unveils a high-end SACD CD player featuring the AKM AK4499EX + AK4191EQ DAC chip combo, XMOS XU316 USB interface and TPA6120 headphone amplification....
Not everething is 5 stars, but the sound deffenetly is!
Achim D.
Great product
Good quality product! The Eversolo sounds very good.
The price is a bit high, and the warranty period could be longer.
(The original power supply for the Eversolo isn't great. There's actually a design flaw in a component.)
Angelo M.
Très bon câble HP
Très bon câble HP pour un prix vraiment honnête. Rien à envier à mes câbles vingt fois plus chers !
Montés sur du matériel vintage (Luxman L30 et Wharfedale Denton 2XP) avec des cosses fourches isolées coudées plaquées or Ø3,5 mm DAYTON AUDIO : très beau rendu sonore et esthétique impeccable.
Angelo M.
Barrette de qualité
Barrette de qualité. J’ai remplacé le câble secteur d’origine, déjà correct, par un câble blindé très facilement.
Destinée plutôt à un usage bureautique (ordinateurs, écrans, etc.), elle reste un bon produit, mais un peu en retrait par rapport aux barrettes en aluminium vendues également par Audiophonics, que je recommande davantage pour un usage audio.
Angelo M.
fourches pour câble HP
Utilisées pour connecter du matériel vintage (Luxman L30 et Wharfedale Denton 2XP) avec du câble AUDIOPHONICS MS4 : que du bonheur ! Sertissage facile et rapide, esthétiquement très réussi, et rien à redire sur la qualité des fourches.
Merci à Audiophonics de proposer du beau matériel avec un excellent rapport qualité/prix.
Alexandre P.
bonne qualité
Du vrai cuivre plaqué et pas du laiton. Très satisfait.
Alexandre P.
Bel upgrade
J'utilisais un petit dac audiophonics usabre, et c'est un sacré progrès. Je ne suis pas un grand spécialiste hifi, toutefois, ce dac produit un son très équilibré très détaillé et ne pardonne pas les mauvais enregistrements. J'en suis très satisfait, l'affichage est très lisible, ce que je reprochais au toppind d50III. Pour le prix il me semble impossible d'être decu
Yuan Z.
7HZ TIMELESS II In-Ear Monitors IEM Planar Magnetic Ø14.5mm 15.2 ohm 108dB 5Hz-40kHz The 7HZ TIMELESS II in-ear monitors, an evolution of the brand's TIMELESS range, are planar-magnetic IEMs featuring a new 14.5mm diameter driver. This driver is itself driven by...
C’est ma première commande chez Audiophonics, et l’expérience a été excellente !
Expédition rapide, livraison tout aussi rapide — c’est parfait !
Le 7Hz Timeless II est exactement à la hauteur de mes attentes : le son planar magnetic est d’un confort et d’une fluidité incomparables.
Mathias L.
très bon ampli mono
bonne fabrication de la part d'Audiophonics pour cet ampli mono à base du module Purifi 1ET6525sa. Le boitier est très joli. Cependant, il y a une chose qui me plait un peu moins et on le ressent à l'écoute, c'est le Désymétriseur. Je pense sincèrement qu'il apporte comme une distorsion ou du bruit. En tout cas l'ampli me semble moins reposant que d'autre ampli Purifi que j'ai eu avant. Ce n'est pas grave en soit, il suffit de brancher une autre prise xlr en direct puisque de toute façon ces ampli purifi sont des amplis symétriques. C'est une bonne initiative de la part d'Audiophonics d'avoir intégré une prise rca mais malheureusement la qualité du signal empathie. Sinon je suis ravi, ce sont de très bons petits blocs mono
Paulo M.
MUSICIAN TAURUS DAC R2R Balanced OS/NOS I2S OCXO 32bit 1536kHz DSD1024 Silver This Taurus balanced R2R DAC from Musician is a high-end DAC incorporating top-of-the-range components and delivering incredibly rich, clear sound reproduction.
Musician Taurus
I´ve teen listening to it for a short time yet, and but I feel I can say that it plays music like a maestro on an orchestra so musica musicality big soundstage great pacing it's simply fabulous next I´ll be upgrading with the Musician Phoenix DDC. My system:
Jeff Rowland Contionuum S2
Conrad Johnson LS17 premier
Belcanto Ref. 1000
Dynaudio C4 Confiodence
Dynaudio S3.46 SVS SB-1000 pro
Sotm 200 ultra neo
Sotm SPS 500 psu
Rose USB hub
Audiqoquest Niagara 1200
Isotek Aquarius
Ludic Kratos
Solildsteel raks
Audioquewst and Viablue cables all Power cables are Pangea
LHY AUDIO SDOP-2 Discrete Double OPA Class A DIP8 (Unit) The  double AOP LHY AUDIO  is a  discrete class A operational amplifier . Mounted on a stand, it offers quick assembly thanks to its  DIP8 format ....
La perfection
Après avoir comparé plusieurs aop sur mon T20 c'est le meilleur et de loin , recomendation changez les 3 aop par celui la
pascal P.
Très bon mais...
Très bon petit appareil, silencieux, au son proche du X2 ce qui est un compliment. Il semble un peu plus doux que le X2. En MC, ce qui est la raison de mon achat, je suis un peu frustré, pas d'effet whaou. A vérifier toutefois sur plus de configurations que la mienne (chez moi, AT-OC9XEB)
Erik L.
SMSL M300 SE DAC Headphone Amplifier 2x CS43131 XMOS Dual Clock NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a...
Quadratisch - Praktisch - Gut
Great little DAC, elegant, easy to set up - sounds great.
Do not let the low price fool you, super sound for peanuts.
Jorge P.
MUSICIAN PEGASUS II Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Silver The Musician Pegasus II presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies,...
Incroyable. Un excellent investissement.
Après avoir utilisé le Pegasus II pendant quelques mois, je peux dire que je suis vraiment ravi. Cela a sans aucun doute été un excellent investissement pour mes oreilles.
Je dois admettre que j'ai été quelque peu déçu les premiers jours. Je me demandais si ce qu'on disait à propos de la nécessité d'une « période de rodage » était vrai. Eh bien oui, tout à fait. Ce DAC a besoin de temps pour se stabiliser, et une fois qu'il l'est... la magie opère.
Je l'ai acheté pour accompagner mon nouveau Shanling Onix Zenith XST20 (transport SACD/CD/MQA), également acheté chez Audiophonics, et je l'ai connecté via I2S. Je l'utilise également avec mon Matrix Audio Element TT-1 Streamer Transporter, connecté via une entrée USB Audio.
Mon système actuel se compose d'une amplification Advance Paris (préamplificateur + amplificateur) et d'enceintes Arendal 1723 Tower. Avec cet ensemble, la lecture de CD est fantastique, même si je trouve parfois les aigus un peu brillants (mes 63 ans et la perte naturelle d'audition dans les hautes fréquences ont également une influence). Dans l'ensemble, le son était très satisfaisant.
Cependant, avec le streamer, les choses changeaient : le son me semblait trop numérique, avec des aigus agressifs, même en utilisant les meilleures plateformes (Qobuz et Tidal). Je préférais le son du CD à celui du streaming.
C'est alors que j'ai décidé d'essayer un DAC R2R, pensant que son caractère plus naturel et analogique pourrait être la solution. En termes de rapport qualité/prix et d'après les avis que j'ai lus, le Pegasus II m'a semblé être le meilleur choix, et je l'ai acheté directement chez Audiophonics, car il n'est pas distribué en Espagne.
Après la période de rodage, le changement a été impressionnant : le son est passé de « bon » à « spectaculaire », surtout en combinaison avec l'Onix Zenith. Les deux forment un ensemble qui, à mon goût, offre un son superbe. À tel point que j'ai résilié mes abonnements à Qobuz et Tidal, et que j'ai recommencé à prendre plaisir à acheter des CD, dont beaucoup d'occasion.
Avec le Matrix TT-1, le saut a également été remarquable. Je ne l'utilise plus pour le streaming, mais comme transport depuis un SSD interne de 2 To contenant ma bibliothèque en FLAC. Grâce au Pegasus II, le résultat sonore est excellent, presque au niveau du transport de CD.
En définitive, le Pegasus II a apporté une amélioration considérable, même à un équipement déjà haut de gamme. Il vaut chaque euro de son prix, et probablement plus.
Enfin, un grand merci à Audiophonics pour son excellent service et la rapidité de la livraison.
Joseph P.
Alimentation 36v 6ampères
J'en avais précédemment pris un et j'en ai acheté un second pour pouvoir alimenter une paire de bloc mono Fosi V3 qui chauffait à plus de 40° avec ses deux alims de 48 volts 5A. Ce n'est plus le cas avec ces deux FX Audio de 36 volts 6A et à même niveau d'écoute, c'est sans aucune différence sur la restitution du son, ( lecteur sac Sony, sortie préampli "direct out" d'un Kora 90 sII et enceintes Davis Matisse. Envoie soigné et respect des délais annoncés bravo et merci à toute l'équipe d'Audiophonics
François M.
XANGSANE XS-A020 RCA Socket Gold Plated Pure Copper (Pair) Xangsane's XS-A020 are gold-plated pure copper RCA plugs, guaranteeing optimum signal transmission while offering ironclad resistance to corrosion and oxidation. Thanks to their...
C'est compliqué la vie
Pourquoi les constructeurs prennent un malin plaisir à compliquer la vie de leurs clients ?
Il faut 2 clés allen , une de 0,9 mm pour le point chaud et une de 1,3 mm pour les masses.
Comprenne qui pourra..
Aritra P.
TECTONIC TEBM65C20F-4 Full Range BMR Speaker 30W 4 Ohm 81dB 60Hz-20kHz Ø7.62cm Tectonic's BMR range consists of full-range speakers designed to cover a very wide part of the audible spectrum. For example, the TEBM65C20F-4 features...
Excellent Full range drivers
Set this up with manufacturer specified 1.6 L cabinets (non ported) made of PETG (3D Printed Boxes). The Clarity of the drivers are remarkable for such a small size. These drivers can be run by themselves eliminating the need for a crossover and tweeter setup.
Bass is a bit on the weaker side. Complementing it with a subwoofer driver is a necessity if you are looking for a rumble.
Overall highly recommended drivers as they are quiet the underdog in the DIY space. Hope more people buy this and enjoy these.
Aritra P.
DAYTON AUDIO LW150-4 Speaker Driver Woofer Low Profile 40W 4 Ohm 86dB 60Hz - 1600Hz Ø15.2cm The versatile Dayton Audio LW150-4 woofer has been designed for space-restricted applications thanks to its shallow depth. Its low-profile frame and unique venting allow the...
Nice Slim Drivers
Based on a preleminary testing, the drivers are of good quality. Bass response is good and the quality of manufacturing is good. Recommended drivers.
ERIC C.
Très bonne gaine
Gaine de très bonne facture, idéal pour habiller mes nouveaux câble de modulation.
leo h.
IAN CANADA CMCHOKER Common Mode Filter Module for Audio Power Supply The Ian Canada CmChoker is a two-stage, high-current, wide-voltage common mode filter that effectively suppresses common mode noise introduced by AC power transformers. The...
Choke
Works perfect
Charles S.
VISHAY ERO MKP1837 Polypropylene Capacitor 5mm 160V 0.1μF Vishay's ERO capacitors are polypropylene film MKP capacitors. They offer good performance in a compact size.
Amélioration générale du rendu sonore et de plages musicales "touchy".
Essayés sur un vieux lecteur cd Marantz CD-52 en parallèle aux condensateurs de sorties, les pattes coupées très courtes¨(5mms) + des résistances Vishay:
des passages difficiles dans les aigus des pianos, le toucher des accords se distinguent mieux, les clarinettes souvent compliquées à bien rendre et cordes passent enfin bien ainsi Stan Getz ! Comme moins de distorsions, plus de nuances, plus bel et plus profond espace sonore. Ceci sans avoir encore attendu les 10 heures que conseille le commentateur précédent.
J'avoue n'avoir, sur mon matériel, jamais apprécié la dureté de sonorité des Wimas; pour moi aucun rapport de musicalité avec ces Vishay. Je n'aurais jamais pensé qu'en tant que simple bricoleur arriver à avoir un rendu aussi propre et musical avec ce vieux lecteur cd. Là, je n'arrête plus d'écouter tant c'est enfin agréable.
Merci à Audiophonics d'avoir choisi de les distribuer !
Ferre l.
JANTZEN AUDIO 000-0826 4N Copper Air Core Wire Coil 29AWG 1mH The Jantzen Audio Air Core Wire Coil is made of high purity Copper wire, offering distortion-free inductance. This makes it suitable for all audio applications. The coil...
High resistance
Si vous achetez ceci, notez que la résistance de la bobine est de 3,9 ohms — cela peut vraiment affecter votre crossover.
Dag-Atle K.
Dag K.
Fantastic sound, similar to the sound of Nad's M23 power amplifier, i.e. very dissolved. But the AUDIOPHONICS LPA-M750ET is more dynamic. Great product for the price!.
Tibor M.
How many reclockers is too many?
Excellent. This has brought the improvements, I wished smsl po100 I bought earlier, would. It does what you guys said it would, clarity and precision is next level, I got better separation and layering out of the music. Voices are really smooth and full sounding! But YMMV, my system is little more complicated now, starting PC + Altor USB Isolator + iFi iPurifier 3 + SMLS PO100 2024 + Audiophonics DigiRescue, all this powered by iFi iPower X 5v + some supercapaticors, coaxial to Topping E70V and Audiophonics HA-B6102 + Burson V6 Vivid + Quad Era-1 / Audio Technica WP900. And I am really impressed how my headphones sounds now, thank you Audiophonics! Peace.
