Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
The Eversolo DMP-A6 Gen 2 is a HiFi network player that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new way of connecting to the world of music. From hardware design to audio processing, every detail of the DMP-A6 Gen 2 has been meticulously designed for audiophiles seeking the...
This Viablue braided sleeve is suitable for cables with a diameter of 2 mm to 6 mm. It is ideal for protecting your high-quality cables against mechanical wear, tearing, twisting and the effects of prolonged exposure to light. Slide the sleeve onto the cables to be covered before assembling the connectors. Use heat-shrink tubing or an adhesive suitable...
This Viablue braided sleeve is suitable for cables with a diameter of 5 mm to 13 mm. It is ideal for protecting your high-quality cables against mechanical wear, tearing, twisting and the effects of prolonged exposure to light. Slide the sleeve onto the cables to be covered before assembling the connectors. Use heat-shrink tubing or an adhesive suitable...
This Viablue braided sleeve is suitable for cables with a diameter of 13 mm to 26 mm. It is ideal for protecting your high-quality cables against mechanical wear, tearing, twisting and the effects of prolonged exposure to light. Slide the sleeve onto the cables to be covered before assembling the connectors. Use heat-shrink tubing or an adhesive suitable...
This USB-A power adapter/charger delivers 5V voltage at 3A current, giving it a maximum power output of 15W. It can be used to charge devices such as phones, tablets, and portable game consoles. You can also use it to power all kinds of audio devices, such as DACs, network players, and digital interfaces.
This Viablue LS-2 Silver speaker cable has two conductors, each composed of 192 silver-plated OFC copper strands, ensuring maximum conductivity. The conductors are insulated with a PE sheath, offering the advantage of significantly lower electrostatic charge than PVC. Each conductor has a cross-section of 1.5mm² for a cable size of 3.5mm thick by...
This Viablue LS-2 Silver speaker cable has two conductors, each composed of 318 silver-plated OFC copper strands, ensuring maximum conductivity. The conductors are insulated with a PE sheath, offering the advantage of significantly lower electrostatic charge than PVC. Each conductor has a cross-section of 2.5mm² for a cable size of 4.5mm thick by...
This Viablue LS-2 Silver speaker cable has two conductors, each composed of 504 silver-plated OFC copper strands, ensuring maximum conductivity. The conductors are insulated with a PE sheath, offering the advantage of significantly lower electrostatic charge than PVC. Each conductor has a cross-section of 4mm² for a cable size of 5.6mm thick by...
With the Pure, Truthear offers high-performance in-ear earphones, direct descendants of the Hexa. Like their predecessors, they are equipped with a combination of four drivers, combining dynamic and balanced armature technology to effectively cover the frequency range, offering balanced sound reproduction with natural timbre and exceptional precision.
Designed specifically for the Eversolo DMP-A6 GEN 1 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA Multicomp Pro extremely linear voltage with low drop and reduced modulation, even under heavy load.
With the LD230TDR08, Atohm presents a high-quality subwoofer driver. The result of proven know-how and all the expertise acquired during the development and production of previous versions since the LD210, this latest generation LD230 ‘TDR’ embodies excellence in covering the 20Hz-300Hz band. Thanks to its advanced technologies, this 23cm...
With the LD230TDR08M, Atohm presents a high-quality subwoofer driver. The result of proven know-how and all the expertise acquired during the development and production of previous versions since the LD210, this latest generation LD230 ‘TDR’ embodies excellence in covering the 20Hz-200Hz band. Thanks to its advanced technologies, this 23cm...
The Moondrop PARA II is a planar magnetic headphones featuring Full Drive Technology (FDT) and large 100mm-diameter diaphragms. The result is rich, precise and dynamic sound reproduction, combined with a wide soundstage for a refined, immersive listening experience. Particular care has been taken to ensure exceptional sound performance in a modern design.
The Moondrop Horizon is an open-back headphone based on a 50mm dynamic driver specially developed by the brand for this model. This new driver is accompanied by an N55 dual magnet magnetic circuit, a combination that delivers a frequency response very close to the VDSF curve, resulting in very present bass, soft treble and a natural overall tone.
With the LD230TDR04, Atohm presents a high-quality subwoofer driver. The result of proven know-how and all the expertise acquired during the development and production of previous versions since the LD210, this latest generation LD230 ‘TDR’ embodies excellence in covering the 20Hz-300Hz band. Thanks to its advanced technologies, this 23cm...
With Daybreak, CrinEar presents a pair of in-ear earphones combining five drivers per side in a hybrid configuration that brings out the best in each technology. Designed to offer neutral sound reproduction with pleasant listening, they combine advanced crossover design with rigorous tuning methodology and optimised wearing comfort. The result is...
These Moondrop EP 100A ear pads are ideal for replacing the ear pads on Moondrop Para headphone. These ear pads are made of leather, fabric and anti-static foam and ensure optimal wearing comfort.
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2 headphones adopt the dynamic transducer and magnetic circuit design that have made the brand so successful. However, the Aria 2 not only retains the technological basis of Moondrop's flagship products, but also combines...
Transform your audio setup into a true high-fidelity wireless system with the CloudyX CL-BOX Pro. This compact audio streamer enables multiroom broadcasting via WiFi and Bluetooth, integrating your speakers or amplifiers into your digital ecosystem for a refined, dematerialized music experience throughout your home.
The Space Travel 2 from Moondrop are wireless in-ear headphones that are the direct successor to the Space Travel. This version retains everything that made its predecessor so successful, while improving various elements such as the speaker and noise reduction. This results in earphones with unbeatable value for money, offering high-quality sound...
This leather protective case has been specially designed to effectively protect Moondrop's Space Travel and Space Travel 2 earphones while allowing convenient access to the case's charging port.
With the ONIX Zenith XDA20, Shanling unveils a high-end DAC and headphone amplifier, combining luxurious design with cutting-edge components. It uses two ES9039Pro DAC chips combined with an in-house developed I/V architecture for digital-to-analogue conversion of rare quality, capable of handling data up to 32-bit 768kHz PCM and DSD512. The amplifier...
Designed specifically for the Eversolo DMP-A6 GEN2 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA NORATEL toroidal transformer, ensuring a stable and silent power supply. The regulation circuit is based on an...
The TinySine AudioB TSA6179 is a Bluetooth 5.0 stereo receiver based on a Qualcomm QCC3031 chip that can be integrated into a wide range of DIY projects to provide your devices with wireless reception. It includes a micro USB port for firmware updates and two buttons that can be assigned to different functions. This version comes directly with a Bluetooth...
The E1DA 9039S is a balanced USB DAC / headphone combo combining high sound performance and ultra-compact design, a direct descendant of the 9038S Gen 3. It is based on the latest ESS ES9039Q2M chip, providing high-resolution decoding up to PCM 32bit 384kHz and DSD256, for extremely fine and precise sound reproduction.
This Tecate TPLH-3R0/3000SL60138 supercapacitor has a high capacity of 3000F and a nominal voltage of 3V. It offers excellent performance, notably with a very low ESR of only 0.26mΩ.
With its QX13, FiiO offers us a relatively affordable portable DAC headphone amplifier based on quality components. Indeed, the QX13 is armed with an 8-channel ES9027PRO DAC chip, a USB XMOS-316 interface and no less than 6 AOPs. This chipset enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while offering up to 2x...
The Fosi Audio I5 Online Version is an open-air Planar Magnetic headphone. They feature a diaphragm no less than 97mm in diameter, offering a wide soundstage. Each driver incorporates a double array of balanced Neodymium N50 magnets for precise, stable diaphragm vibration. This greatly reduces any form of distortion for a clear, authentic sound...
The Fosi Audio I5 OFFLINE VERSION is an open-air Planar Magnetic headphone. They feature a diaphragm no less than 97mm in diameter, offering a wide soundstage. Each driver incorporates a double array of balanced Neodymium N50 magnets for precise, stable diaphragm vibration. This greatly reduces any form of distortion for a clear, authentic sound...
The FiiO E-Stick is a portable battery designed for use with the brand's KA17 and QX13 DAC headphone amplifiers. This portable battery offers up to 5 hours of autonomy.
The Fosi Audio GR70 is a headphone amplifier based on a combination of 2 x 564AW and 2 x 6AC7 tubes. As a result, it delivers a smooth, warm and authentic sound. Thanks to its LOW/HIGH gain control, it can drive headphones with impedances ranging from 16 ohms to 300 ohms.
The Audiophonics NL8802 is a high-quality MUSES dual OPA offering a wide operating voltage range, very low noise and distortion, excellent bandwidth and high slew rate. It is ideal for preamplifier or active filter designs.
WiiM offers a voice-activated Bluetooth remote control compatible with its entire product range. This remote control features a premium design and intelligent functionalities for a practical Wiim ecosystem that's fun to control.
This Topping pack, comprising the D900 DAC, the A900 headphone amplifier and preamplifier, and a pair of 25cm TCX1 XLR cables, will enable you to enjoy exceptional sound quality, both on headphones and in classic integration with a power amplifier.
The WiiM Amp Ultra is the culmination of a new generation of connected amplifiers, designed to meet the highest expectations of modern audiophiles and audio technology enthusiasts. With its meticulous design, remarkable power and network intelligence, this all-in-one device brilliantly combines high-performance amplifier, audiophile streamer and high-end...
