Holo Audio unveils with the Spring 3 a beautiful R2R DAC / preamplifier based on discrete components. Custom designed, it offers incredible performances thanks to its Trickle Down technology. Its particular architecture allows it to deliver a sound restitution of an unbelievable richness and purity. It embeds two totally separate circuits, one in charge...
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with high-end components, it provides a high quality sound reproduction that is as rich and precise as it is dynamic.
this passive attenuator uses a precision resistor that is connected in parallel with a 1% SMD mechanical resistance switch. this resistor is connected to the potentiometer, which, depending on its position, more or less connects the output to ground and thus varies the volume.
Both passive preamplifier and source selector, this aluminum and wood finish unit will surely convince you. It is equipped with very high quality components assembled by hand with the utmost care. In addition to its magnificent realization, this volume controller has the best technical features.
The LADDER Bach II is a preamplifier designed to bridge the gap between audio sources and power amplifiers. It features a discrete Class A balanced design combined with a 60-step relay-based volume control. Designed for versatile Hi-Fi integration, it offers both single-ended RCA and balanced XLR connectors for input and output. In addition, it features a...
The LAiV Crescendo Verse is a high-end, all-in-one audio solution combining a discrete R-2R DAC, a discrete buffered output preamplifier, and a discrete headphone amplifier in a single compact and versatile device. It is based on LAiV's proprietary R-2R architecture, designed to deliver natural tonal reproduction and detailed precision, as well as native...
The LAiV Crescendo VERSE is a high-end, all-in-one audio solution combining a discrete R-2R DAC, a buffered output preamplifier, and a discrete headphone amplifier in a single compact and versatile device. It is based on LAiV's proprietary R-2R architecture, designed to deliver natural tonal reproduction and detailed precision, as well as native 1-bit DSD...
LAiV's Harmony HP2A is a preamplifier and headphone amplifier meticulously designed for discerning audiophiles who demand uncompromising sound quality.
The Luxsin X8 is a high-end all-in-one audio solution designed for demanding audiophiles, combining the functions of a DAC, headphone amplifier, and preamplifier. As such, it combines a powerful digital-to-analog converter, a headphone amplifier capable of driving even the most power-hungry headphones, advanced DSP with AI-assisted equalization, an...
The Matrix MS-1 PRE audio network player is an extremely complete streamer that forms part of the brand's M series along with the MP-1 preamplifier and MA-1 power amplifier. This new series features a new design, both in terms of appearance and internal structure. Indeed, the MS-1 PRE network player features a balanced structure with a combo of AKM...
The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line input stage. Its volume control uses relay-controlled R2R resistors for constant output impedance and exceptional sound quality.
Extremely versatile and generous in its features, the NAD C658 is an integrated solution, which is at the same time an audio network player, a high-resolution audiophile DAC and a stereo and phono preamplifier. It is compatible with the BluOS application developed by BlueSound, allowing remote control of the player as well as multi-room integration.
This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two buttons on the front panel will be able to allow all cases of RCA to XLR, XLR, to RCA, RCA to RCA or even XLR to XLR.
Silkline's Zuki I combines the functions of preamplifier and DAC. The preamplifier function has a balanced and unbalanced output and a voltage gain of 12dB. High-performance ADI AD1955 conversion chip decodes up to 32-bit / 192Khz PCM.
The Singxer SA-2 is positioned as a high-end headphone amplifier and preamplifier, fully balanced and featuring pure Class A architecture. Designed for audiophiles and users of high-performance headphones, it succeeds the highly regarded SA-1 by offering increased power and control.
The SMSL VMV P2 is a high-performance preamplifier - desktop headphone amplifier, capable of delivering high power and extremely accurate sound reproduction. It is based on a carefully designed balanced architecture, enabling it to deliver 2x6W at 32 Ohm or 2x350mW at 600 Ohm. The whole unit is housed in a magnificent aluminum chassis, as robust as it is...
The Soncoz QXA1 is both a headphone amplifier and a preamplifier, supported by a high quality balanced architecture, using components selected for their performance and their ability to provide a pure and accurate sound reproduction.
Soncoz unveils with its SGA1 a fully balanced headphone amplifier and preamplifier combo that is extremely powerful and musical. Benefiting from an intelligent and neat architecture as well as a sober and elegant design, it will delight the most demanding audiophiles and music lovers.
Sparkos offers with the Aries a high-end preamplifier and headphone amplifier for audiophiles looking for the best sound quality. It is based on an architecture composed solely of discrete components to ensure exceptional performance.
This Gemini headphone amplifier/preamplifier from Sparkos is a jewel of hybrid technology, whose main feature is the possibility of customizing it to suit your listening preferences and your Hi-Fi installation. It's called hybrid because its amplification stage comprises both a 6922 tube (also known as an ECC88) and a SS2590 discrete AOP.
This balancer has an unbalanced stereo RCA input and a balanced stereo XLR output. It will allow you to provide a balanced output to an audio device that does not have one
This TinySine TSA1110 will allow you to control the volume of your audio system of your choice via the rotary knob on the case or remotely, directly via your smartphone.
The Tonewinner AD-1PRE+ is a versatile preamplifier that offers a number of interesting features. In fact, it incorporates quality components such as an ES9038 DAC chip combined with two optical inputs, a CT7601PR USB interface, as well as a combination of no less than 9 AOPs (5x OPA1612, 4x OPA1632, 1x OPA1642) and a MUSES72323 volume controller. These...
The Topping A70 PRO is an efficient and affordable headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear headphone listening. The amplifier is Hi-Res certified, a label guaranteeing a very good quality of sound reproduction.
Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it incorporates a discrete NFCA amplifier stage capable of supporting most headphones on the market. Its careful design using many high-end components allows it to deliver a rich, clear and...
The Topping A900 is a high-end headphone amplifier and preamplifier, combining power, performance and design. It benefits from T'ang-ku-la's proprietary balanced amplification architecture, enabling it to develop significant power, making it capable of accompanying the vast majority of audio headphones. What's more, in addition to its exceptional...
Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced performance and a better user experience. This D90 III DAC incorporates an ESS ES9039SPRO DAC chip per channel, a USB XMOS interface upgraded to an XU-316 and a new Qualcomm QCC5125...
The Topping DX9 DISCRETE is an R2R DAC/headphone amplifier with even better performance than its predecessor, the DX9, which was based on AKM technology. the DX9 DISCRETE is based on a balanced PSRM circuit with 16 elements per channel combined with R2R resistor networks, as well as an AK4118 optical receiver chip and an XMOS XU-316 USB interface,...
The Topping E50 II, an evolution of the E50, is a DAC that offers excellent performance thanks to meticulously selected components. It also features a number of improvements in terms of functionality compared to its little brother. The E50 II benefits from an AK4497S chip coupled with an XMOS XU316 interface, enabling it to support high-resolution...
