Connector
Impedance (Ω)
Max cable diameter (mm)
Efficiency / Sensitivity (dB)
78 - 128
Lowest frequency (Hz)
0 - 2010
Highest frequency (Hz)
0 - 113000
Max sampling rate
Material
Power (W)
10 - 1000
Speaker type
Connectic
Length
0 m - 5 m
Section (mm²)
0 mm - 1 mm
Conductors material (Cable)
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 4
Input
Output
Mounting type
Remote Control
Transmission / Reception protocol
Streaming services
Color
Conductors Plating (Cable)
Number of loudspeakers
Insulation material
Shielding
Supported Bluetooth codecs
Wireless
Noise reduction
Phone call feature
Speakers and Headphones
Stephane G.
Incroyable !!
Je possède depuis une vingtaine d’années du Naim Audio (NAC 282 / HICAP / NAP 250.2) couplé à des ATC SCM 50 Passives.
Très...
Attention fragile
La conception est fragile et le conditionnement très sommaire : certaines des vis sont coincées dans la banane.
Egalement,...
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black...
Discover our range of headphones and speakers to accompany your HiFi system and offer you high quality listening.
  • Passive Speakers and Subwoofer
    We regularly offer you all our DIY setups and realizations, but we also have a range of HiFi speakers and passive subwoofers: bookshelves, satellites, or columns, selected by our experts to offer you a sound rendering that meets your expectations. All the parts of a HiFi installation are important, the speakers in particular, as well as the amplifier and the connections that will accompany them.
  • Active Speakers and Subwoofer
    Find in this category all our active speakers and subwoofers, including an amplifier module for a quick and easy installation.
  • Speaker Supports
    Speaker Supports
    Discover our range of speaker stands, allowing you to place, hold and cushion your speakers in a practical and efficient way.
  • Headphones
    Headphones
  • In-Ear Earphones
    In-Ear Earphones
    Here you'll find our selection of HiFi in-ear monitors. High-performance headphones capable of meeting every audiophile need and requirement. We strongly recommend pairing these earphones with a HiFi walkman of the same quality, i.e. one capable of processing high-fidelity music formats.
    Special conditions apply for a withdrawal on this type of product  => See our General Terms and Conditions.
  • Headphones & In-Ear Monitors Accessories
  • Ref : 21880
    In Stock
    The XCITE XBS50MK is a mounting bracket designed specifically for the brand’s XBS50-4 exciter. It is designed to provide a mechanically stable mounting whilst optimising the transfer of vibrational energy to the host structure. It is built on a glass-fibre-reinforced ABS base incorporating copper inserts, which provide long-lasting protection for...
    9,90 € 8,25 €Ex.
    In Stock
