Jean-Claude F.
Très bon câble HP
Jean-Claude F.
Yvain C.
J’ai hâte de la...
Julian V.
TOPPING D90 III DISCRETE Balanced Discrete DAC Bluetooth 5.1 32bit 768kHz DSD512 Silver The D90 III Discrete balanced DAC from Topping is the parallel to the D90III using a 100% discrete digital/analogue conversion module. Here, conversion is performed by a PSRM...
Very good dac
Very pleasing to listen to and all the great Reviews are true. A wholehearted recommendation from my side and also for audiophonics for very quick Processing
Hocine H.
Très bon câble.
Agréablement surpris par ce câble à un très bon RqP. Câble relativement souple et facile à travailler, on ressent le savoir faire et la qualité NEOTECH.
Utilisé avec des RCA DG-201, ils viennent en remplacement de câbles symétriques pur argent (retour au cuivre).
Un bel équilibre sur tout le spectre, mais par dessus tout, les voix sont plus claires sans être mise en avant. 4 conducteurs mixtes (multi brins et mono), j'ai testé les variantes et le couplage mono-multi ensemble me convient mieux. Je conseille vivement.
Massimiliano G.
AUDALYTIC HP70 Headphone Amplifier Preamplifier Balanced Silver The Audalytic HP70 is a high-end headphone amplifier and preamplifier designed to deliver exceptional sound quality thanks to its fully balanced and discrete architecture....
very good value for money, but needs good matching with power amp
Despite the size the HP70 is a rather solid and well built item; much better in real life than in a picture. I bought it to use it in a second system but I first tested it in my main system, with a Lector 0.6T CD player, Norma power amp and Spendor A7 speakers. Its gain was set at the maximum (+28dB) but I noticed that in order to have a familiar sound pressure level I had to use volume levels of about 70/100 or more. Even removing the psychological effect of rotating the volume knob up to there, I thought it was giving me not much useful range with the volume. The sound quality was very good indeed: it was a very clean (no background noise at all) and very detailed presentation, pretty neutral but not too cold, really impressive considering the size and value of the object. Then I tested it on the other system (Thorens TD124/Denon DL110, Manley Chinook, XTZ Edge power amp and Diapason Adamants speakers), and here the situation was much better. The pressure was more convincing. The volume level was around 60/100, still a bit high but more manageable. I guess the key is a different input sensitivity of the power amp. So I have decided to keep it. I will use it mainly as a preamplifier. Probably as headphones amp it is more universal, but if you want to use it as line preamp have a look at the input sensitivity of your power amp: 2V or close can be too low sensitivity.
Hocine H.
Grosse erreur de ma part.
Je reviens sur mon avis précédent, fais plus par colère qu'objectivité.
La tête n'est pas à enlever, il faut juste souder les conducteurs à travers les fenêtres du connecteurs. Cela demande de la précision et l'espace est très restreint, pas des plus pratiques, mais avec de la patience on y arrive.
Par contre, je reste sur mon choix futur, plus jamais WBT, car il faut avoir la minutie d'un horloger Suisse, la patience d'un Taoïste et d'un calme stoïque. Encore dommage qu'il n'y ait rien sur le net sur ces connecteurs.
Enrico N.
Così piccolo così incredibile!
È veramente stupefacente, suona meglio di moltissimi DAC che costano dieci volte il prezzo del Topping E70 Velvet! Rapporto qualità prezzo inarrivabile! Veramente un piccolo Grande Gioiello!
ANTONIO M.
SONIDO PERFECTO PERO SE PONE AL ROJO VIVO
SONIDO NIVEL PURIFI PERO SE PONE TAN CALIENTE QUE QUEMA, AL FINAL ME DESHICE DE EL ANTES DE QUE SE FUNDIERA
ANTONIO M.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Pair) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
HAY DIFERENCIA
MAS CUERPO MAS CALIDEZ UN TONO....MAS TONO... NO ES HYPE ES REAL
ANTONIO M.
3E AUDIO 480-1-29A PFFB Mono Balanced Class D Amplifier Module TPA3255 1x480W 2 Ohm This 3E Audio 480-1-29A amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W into 2 Ohm (@ 1% THD+N, 1kHz)...
correccion: EXCEPCIONAL
Despues de años de volver a construir unos monobloques, con fuente de alimentacion lineal dedicada y todo balanceado monobloques separados ...corrijo ¡es mejor que purifi 1et400a!!!! lo tiene todo cuerpo, extension detalle limpieza, un tono casi clase A... espectacular!!!!
Luis V.
Mice
Very mice product
Stephen G.
Pleasantly surprised.
Purchased this to compliment my Canton Vento 896 DCs for front L/R operations - these were previously driven solely by my Denon X4400H. The amp upgrade was intend d to provide more headroom (50/50 music/movies). I wasn’t expecting a massive difference in SQ, but I was quite mistaken - the bass has noticeably more ‘slam’ and drives the woofers with much more perceived precision and speed. Midrange, particularly vocals, are much more present. All in all, a marked improvement. Great work by the team at Audiophonics - so far, I can highly recommend!
DIMITRIS D.
True Audio!
To find a decent quality DAC, you have to pay more than 300 euros, but this little miracle it costs cheap, but it delivers sound that can compare with some of the most expensive Dac's!.
The sound from the USB port source that i'm using (Computer, preAMP-Mixer, Technics AMP, Crystal Audio Pisma speakers) is excellent.
Previously i was converting music from a Cambridge DACmagic that was very-very good, but the SMSL SU-1 delivers full sound quality similar to a CD. Everything is much clear, the bass is warm and powerful and the trebles are soft and you can hear clear all the frequencies.
In That price i think SMSL SU-1 is one of the most valuable Dac's in the market!
Vladislav B.
IFI AUDIO GO BLU AIR Portable DAC Headphone Amplifier CS43131 Bluetooth 5.2 aptX Adaptive LDAC LHDC The iFi Audio GO Blu Air is a portable Bluetooth DAC and headphone amplifier designed to follow you everywhere. Both practical and high-performance, it features a magnetic clip...
Great and small device
Great device, tested out only the 3.5mm jack. Plays loudly and cleanly on Crinacle zero Red.
The only drawback is that the volume wheel ignores input if turned too quickly. About 1 revolution per second is its maximum speed, anything faster and the volume barely moves, so you need to be patient when you need to adjust the volume quickly
Samir H.
Wiring Cable Single Strand Silver Plated OFC Copper PTFE Sheath 0.5mm² Ø1.3mm Red This wire is ideal for internal wiring on DIY projects. It consists of a 0.5mm² silver-plated OFC copper single-strand conductor. This cable is...
Rigide et chiant
Trop rigide à mon goût et franchement chiant à dénuder. Pas facile à travailler.
Philippe V.
SMSL D100 DAC Headphone Amplifier XMOS XU316 ES9081 32bit 768kHz DSD512 Silver The SMSL D100 is an all-in-one desktop DAC and headphone amplifier built around the ESS ES9081 chip, using all eight channels in parallel summing mode to achieve a dynamic range...
Epatant
Testé avec Sennheiser HD660S . Des basses extra avec Bernard Lavilliers. Impossible de maintenir le volume au max. En tout cas pas de saturations. j'ai découvert la possibilité avec l'entrée USB l'utilisation en nomade sur batterie du player bien sur l'autonomie s'en ressent mais sans excès ( sur Hiby R4).Léger,, peu encomrant, autonome si besoin, très simple et clair. Qualité du décodage il na pas a rougir a la comparaison avec mon SMSL C200
DD TC01BF USB-C Male to USB-B Female Adapter Gold-plated The TC01BF adapter from ddHiFi consists of a female USB-B connector and a male USB-C connector. Its gold-plated contacts ensure good conductivity and resistance to oxidation....
Adaptateur choisis pour relier mes enceintes Créative T60 à mon pc via un câble DIY j’ai été très étonné par la qualité sonore par rapport à un autre adaptateur bon marché. Le son est plus posé et détaillé. Bien respecter la phase de branchement de l’USB-C qu’il suffit de retourner, pratique!
MOONDROP NICE BUDS Dynamic Earphones 32 Ohm 122dB 20Hz-20kHz Black The Moondrop Nice Buds are earphones featuring a 15.4mm dynamic driver. Their acoustic structure incorporates a dedicated airflow tube that enhances bass response for a more...
Petits écouteurs de très bonne qualité sonore. Ce ne sont pas les meilleurs mais pour le prix ils sont imbattables.
Hocine H.
Belle surprise.
Acheté sur un coup de tête par curiosité il y a 1 an. Je l'installe 1 an plus tard, en me disant pourquoi pas ?
C'est une belle surprise, en plus sur un pc il est facile de switcher d'un port usb à l'autre, me disant que c'était un effet psycho, mais non, le résultat est là. La grande amélioration est dans les noirs, ce qui donne plus de relief et une douceur à la musique. Bravo, à ce prix c'est cadeau et je conseille un bon câble usb / dc pour l'alimenter ou encore si votre budget le permet, une bonne alim.
Serge M.
Très très bon ampli !!!
J'ai fait l'acquisition de 4 amplis LPA-S600NCX pour alimenter une installation a très haut rendement en 2 x 4 voies.
C'est un pur bonheur, ca marche du grave à l'aigue, avec finesse et force sans aucune agressivité. Pas un pet de souffle dans mes compressions. Est-ce l'ampli ultime ? Je ne sais pas, mais en tout cas, j'ai fini de chercher.
Diederik v.
AUDIOPHONICS HC TRIGGER SWITCH MKII Home Cinema Power Trigger Symmetrizer / Desymmetrizer The Audiophonics HC Trigger Switch MKII is a pilot-controlled source selector whose main purpose is to enable you to use your Hi-Fi system as the front channels of your home...
Finally I can merge my DAC and AVR
Audiophonics did a great job with this device. It perfectly solves having a great stereo en surround system with the same pair of balanced active front speakers. I connected my Denon AVR to this and the RCA signal is perfectly converted to a balanced signal. No pops hums etc. Recommend this device for anyone who wants to combine stereo balanced and unbalanced HT equipment.
DOUK AUDIO T6PRO Hybrid Class D Amplifier TPA3255 JAN5725 Tube Bluetooth 5.1 aptX HD LDAC 2x 250W 4 Ohm Yellow The Douk Audio T6PRO is a hybrid HiFi amplifier combining tube amplification and modern Class D technology to deliver a sound reproduction that is both warm, dynamic, and...
Peu mieux faire
Attendre un rodage avant jugement . On a plus la sensation t 'entendre un ampli à transistor , on ne retrouve pas la magie du tube . Alimente deux enceintes colonnes trois voies . Vu la puissance annoncée je m' attendais à mieux , il faut pousser le niveau de grave a plus de 3/4 du réglage et le super bass a + de 1/4 et celà reste passable. le son ne décolle pas des enceintes et la restitution reste trop sage et un peu en retenue . Le son n'est pas mauvais ( transparence et définition ) mais sa manque d ' enthousiasme . Ecouté uniquement en bluetooth ldac ( peut être que la section bluetooth est un peu faiblarde? ) il me semble que cet appareil est plus approrié pour les petites enceintes dans une salle d' écoute pas trop vaste . Dans cette fourchette de prix on trouve plus punchy et plus vivant musicalement .
Bernard G.
ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB Black (Pair) The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter...
Une petite révélation...
Aucun rodage nécessaire. Pièce traitée de 22 m2, écoute tout styles à 85 db SPL, séparées de 2m50 et écoute à 2m50 de distance, en comparaison avec JMR Abscisse, Dac Velvet, Purifi LPA-S400ET, cables Mogami.
Scène sonore profonde mais moins large et plus centrée, Capacité dynamique moindre mais suffisante en Hifi, et surtout réponse infra-grave assez étonnante pour la taile (niveau intéressant à 35 Hz), ne nécessitant à mon avis un SUB qu'en Home cinéma. Aigü détailé mais plutôt doux, un poil chaleureux dans le bas-médium, mais rendu neutre et très naturel. Pas d'égalisation.
Les fiches bananes ne s'enfoncent pas assez dans les bornes HP et garder au moins 10 cm pour le débattement des HP passifs à l'arrière.
Pour moi rapport qualité/prix exceptionnel. Un must!...
Tomas C.
AUDIOPHONICS HPA-INT450ET Integrated Amplifier Stereo Class D Purifi 1ET6525SA 2x450W 4 Ohm Audiophonics is proud to present the HPA-INT450ET. This Class D integrated amplifier relies on a pair of Purifi 1ET6525SA amplifier modules coupled with a Hypex SMPS1200A400...
Very good, very well controlled bass. Via preout I connected my subs and thats the best I've heard from these subs ever.
No sharpness just pure music joy.
Richard H.
FIIO K13 DAC R2R Headphone Amplifier 32bit 384kHz DSD256 Black The FiiO K13 is a versatile device that acts as both a DAC and headphone amplifier. Digital-to-analogue conversion is handled by a balanced R2R resistor network, supporting...
FiiO K13 R2R DACamplifier
Absolutely superb. Everything I hoped it would be and more! If you're hesitating to buy then don't! Apart from the obvious compliments about sound quality and power, I love the parametric EQ in particular. I added a large dose of sub bass to the EQ for my DT770 PRO's and the results were absolutely staggering with electronic music from Yello for example. To have what amounts to digital tone controls is marvelous. I have hearing damage around 4khz and I'm able to correct for this so easily!
Sound is often holographic with Planar Magnetic IEM's or headphones. Occasionally, with certain genre's, the music almost seems to get lost within the soundstage! Strange until used to it.
The flexibility the K13 provides is excellent! Lots of inputs and outputs balanced and unbalanced lots of menu options, remote control ,great LDAC 96khz 24bit Bluetooth implementation, excellent build quality etc. etc.
I hate to say it but I think this unit is priced way to low! Unusual to be able to say that itoday! Thank goodness for companies like FiiO. I can't imagine how much a device like this would have cost 20 years ago especially with an R2R DAC inside!
I would say that the K13 would probably be end game for most users like myself who are discerning but can't or don't want to spend thousands more ...!
An easy five star buy for once.
Daniel Z.
j'ai 2 BST 300EX + 1 minidsp 2x4hd car indispensable pour faire un filtrage et grace à IA j'ai beaucoup affiner les réglages pour éviter trop de vibrations nuisibles. Que du bonheur et de très grandes qualités j ai faillit acheter les earthquake et merci au site (concurrent) d'avoir augmenté le prix pour la fête des péres du coup je suis venu sur audiophonics acheter les dayton et je ne regrette pas du tout
Patrick M.
FOSI AUDIO ZA3-48V Stereo / Mono Class D Amplifier TPA3255 2x150W 4 Ohm / 1x240W 4 Ohm This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It...
Surprenant!
Petit ampli étonnant qui peut rivaliser avec des amplis beaucoup plus chère . associées avec des Rogers LS3/5 c'est top plus un caisson de basse, le résultat est très bon, pas de dureté dans les aigu. un son naturel avec une bonne réserve de puissance.
le seul défaut c'est qu'il chauffe pas mal ?
Aleksandr P.
NEOTECH NC-01675RH Banana Plugs Rhodium Plated OFC Copper Cryo Treatment Ø8mm (Set x4) These Neotech NC-01675RH banana plugs feature excellent design quality and are ideal for creating high-performance HiFi speaker cables. The contacts are made of Rhodium-plated...
Neotech NC-01675RH
Excellent Banana plugs - strong, big inner diameter, transparent for sound signal. I have terminated my speaker cable Neotech NES-3003 MK2 with these banana plugs, understand they are ideal for this thick cable by dimensions and sonically. Bare ends of speaker cable were first crimped with Furutech crimping sleeves then installed inside and fixed with screws. Good result, good sound.
Gain sonore significatif
Câblé entre un réducteur de bruit Fosi audio et un préampli à tubes Aiyima . Gain en propreté d'image et de netteté sonore sans avoir à tendre l'oreille . Peut être un peu cher mais résultat au rendez_vous .
Silicone Damping Ring for Tubes Ø24/18mm This silicone tube ring dampens vibrations. It has an outer diameter of 24mm and an inner diameter of 18mm. It is compatible with 12AX7, 12AU7, 12AT7, 12BH7, ECC88, EL84, and...
efficace
Gain très audible en netteté de son . En regard du prix à essayer sans restriction .
Aleksandr P.
Neotech NES-3003 MK2 Speaker Cable
Magnificent cable, giving transparent, detailed and at same time musical sound. But it needs break-in about 100 hrs or more - in the middle of this period sound in my system was distorted (too bright). I have terminated the cable with banana plugs NEOTECH NC-01675RH, understand they are ideal for this thick cable by dimensions and sonically. I have 2 speaker cable more, one of them is top Furutech model, 4 times more expensive, also very good. Comparing them I dare to say they are both of approx same level, Furutech gives more neutral musical sound, Neotech NES-3003 MK2 - more refined.
Nicolas S.
ASCILAB C6B Bookshelf Speakers 250W 4 Ohm 85dB Gray (Pair) The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina-ceramic dome...
Superbes et réjouissantes C6B
Premières heures d’écoute absolument bluffantes. Le son est très naturel, avec une belle précision dans les détails et une scène large sans être artificielle. Les basses sont étonnamment vraiment bien détaillées même si ça ne descend pas très bas (mais rien d'anormal pour des bibliothèques), et le rendu global est très cohérent, que ce soit sur du jazz, de l’électro ou du triphop.
Petite précision utile pour les futurs acheteurs : la finition est gris mat donc différent de ce que peuvent laisser penser certaines images d’illustration qui donnent une impression de beige laqué.
Pour le rapport qualité/prix, je suis vraiment bluffé.
Guy P.
XDUOO MX-02 Bluetooth 5.4 Transmitter LE Audio aptX Adaptive The xDuoo MX-02 is a high-definition Bluetooth audio transmitter designed to transform your wired audio sources into a high-quality wireless experience. With its versatile...
Parfait pour mon usage
Je me sers du XDUOO MX-02 pour raccorder un casque Focal Bathys à mon ampli. La liaison est optimale même éloigné de la source (2 étage de séparation dans une maison individuelle).
Par contre, il y a un détail qui est un peu agaçant. Il ne dispose pas d'une option pour désactiver le clignotement du gros bouton quand il n'est pas appairé. L'appareil clignote en permanence d'une façon peu discrète. Il faut débrancher l'appareil pour arrêter le clignotement. A revoir.
Adnane b.
Douceur et matière
Sur des casques comme un hifiman Arya, font des merveilles sur le bas du spectre (bas médiums basses) et calment les sibilances éventuelles.
Bon aussi sur des HP (mais moins waouw que casque)
Adnane b.
[GRADE A] GUSTARD X26III DAC 2x ES9039SPRO NOS Streamers LAN Roon Airplay UPnP 32bit 768kHz DSD512 Black Refurbished product - Grade A Gustard's X26III is a balanced DAC and streamer based on two top-of-the-range ES9039SPRO DAC chips, offering accurate conversion of PCM up...
Bluffé!
Un Dac steamer vraiment incroyable , jusqu’ici c’est le meilleur compromis que j’ai entendu entre précision, impact dans les basses et douceur des médiums… et ceci sur des puces Sabre dont l’implémentation peut facilement pousser un peu loin les aigus et oublier les médiums charnus. Connecté sur un gustard h26 , avec son streamer intégré (très bon, pas sûr de trouver quelque chose de meilleur à moins de 1000 euros) je le préfère même à mon R26 original. Bref à conseiller vivement !
Active SPDIF Optical Toslink Switch 3 to 1 This SPDIF switch has three inputs and one output in Toslink optical format. It allows you to multiply the number of sources for the same output, and to easily select the active...
Fait très bien ce qu'on lui demande, avec un corps en métal très solide.Je recommande.
Patrik E.
Microphone for Dirac Measurement
The UMIK-1 is a well built measuring microphone you need to set up a Dirac system. It is well built and comes with a little stand and a connector-cable. The microphone works well and did everything it should during the measurement.
Positive:
Build quality
Performance
Negative:
Clamp of micro-holder to tight (hard to get micro in it.
Enclosed cable is USB-A to USB-C (pure USB-C would be more up to date)
A bit pricey for a one use item.
Patrik E.
TONEWINNER AT-600 Audio-Video Processor / Home Theater Preamplifier 8K Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-600 is a 8K 16-channel home theater processor designed for processing immersive configurations up to 9.3.4, relying on a dual-core DSP combined with an ESS DAC...
Great AV-processor with Dirac for incredible value.
The Tonewinner AT-600 is a solidly built AV-processor with a ton of connectivity and a full set of dirac-features built in. My system: 7.2.4 with Tonewinner 7 Ch-Amp and NAD 4-Ch-Amp and B&W for speakers. First impressions: The case of the processor feels solid, all the connectors are gold-plated. The unit looks nice and clean with its big volume-dial in the middle and the two displays to the left and the right. The displays are big and can be set at different brightness-levels. The remote has a metal top face and is sturdy but it does not allow for the selection of all inputs. You have to use the smartphone app for that. Setup Before anything else, hook up the processor to the screen and set the speaker-configuration and the number of Subwoofers. You cannot configure this in the app. I last made a full Dirac setup with an older system more than 6 years ago and should have remembered how important setting all the speakers to a similar level is. So: do this first, if you don't want to have crazy bass-levels! For Dirac, you have to have a special microphone that is NOT included. The included micro only works with Tonewinner's own room-correction system! The Processor and the Computer to which the micro for Dircac is connected have to be in the same WIFI-Network. Sound and Picture The sound after the correct dirac-measurement was really great, clear and crisp. The spacial impression of the soundstage was both deep and wide. I lowered the bass-levels slightly, but this was the only adjustment I made. The picture quality is as expected, since I leave all the processing to the players and the projector and the processor has to just forward the signal. Operation The remote-control gives you direct access to three inputs you can define yourself. To select other inputs you have to use the input selection key that gives you the list of all inputs on screen you can select from. The Input selection through the app works better. Input switching is quick and reliable. The sound- and picture-formats are correctly identified and displayed on the left screen. The startup of the processor is sufficiently quick. There are two graphics on the screen when powering down. it would be nice if the user could customize them. Conclusion: The AT-600 is a great piece of AV-gear at a very good price considering the quality, connectivity and the fact that Dirac Live with Room Correction, Bass Control and Active Room Treatment are included. The build-quality seems to be very good, and the performance is more than satisfying. As for any niggles, they are minor and few: - DLNA-Compatibility would be nice, since the AT-600 has already the capability to play music-files from SD-Cards and USB-Drives and also has a permanent Network Connection. Allow for the reassigning of the symmetric outputs of the central Ceiling speakers as SW 2 and 3. This way a 7.2/3.4. system could be hooked up fully symmetrically. Recommendation: Go for it. If you have an extended AV-System and a tricky room that needs a good sound management, the AT-600 delivers at a price that is actually astounding.
Olivier B.
[GRADE S] SHANLING UA1 PLUS Portable USB-C DAC / Headphone Amplifier 2xCS43131 32bit 768kHz DSD512 Black Refurbished Product - Grade S With the UA1 Plus USB-C DAC and portable headphone amplifier, Shanling is unveiling an ultra-compact, affordable device that will let you play...
SHANLING UA1 PLUS : parfait
Testé via les prises USB C de mon Samsung S8, de ma tour (sortie USB-C de ma carte-mère) pour alimenter mon ampli vintage Luxman et mes enceintes de monitoring. Le résultat est vraiment très bon. J'adore !
Fabrizio M.
Rotary switch 250V 3A Smooth Axis This rotary switch is a bistable switch. It has one pole and two positions (ON/OFF).
INTERRUTTORE ROTATIVO
Finalmente un fornitore che tiene a magazzino un ottimo! interruttore rotativo.
Laurent C.
Quelle énergie !
Câble fantastique, intouchable sur une barrette secteur, délivre une énergie impressionnante. Monté avec un schuko viborg or et iec viborg rhodium, ça envoie, c'est précis sur tout le spectre. Polyvalent, il est excellent sur un ampli aussi.
Jesse D.
AC/DC Switching Power Adapter 100-240VAC to 42V DC 7.5A This power adapter takes in input a voltage of 100-240VAC and allows to have in output a voltage of 42V DC for a current of 7.5A. Its output connector is a DC 5.5/2.5mm jack,...
Convient parfaitement pour l'utilisation avec un amplificateur de classe D qui utilise une puce de chez TEXAS INSTRUMENTS (TPA3255) pour un gain non négligeable de puissance sans chauffer autant qu'avec une alimentation de 48V (5A ou 10A) en mode veille ("IDLE").
A recommander !
Nicolas S.
Petite précision utile pour les futurs acheteurs : la finition est gris donc différent de ce que peuvent laisser penser certaines images d’illustration qui donnent une impression de laqué.
SHANLING MTW200 PLUS True Wireless Dynamic In-Ear Monitors IEM Ø10mm 32Ω 112dB 20Hz-20kHz With the MTW200 Plus, Shanling presents us with wireless in-ear earphones. The brand has opted for a dynamic 10mm driver with a titanium membrane, coupled with a special...
Moyen
Tout est dit. En comparaison avec des Jabra Elite 5 que j'ai perdu, c'est moins bien.
Le boitier en alu est trop petit et paradoxalement trop lourd. Certes il se glisse très facilement dans une poche, un peu trop facilement même. Il est donc facile à perdre. L'alu et le système d'ouverture fait un peu trop "charnière", mais ça fonctionne bien.
L'écoute est moyenne (ni bien ni mauvaise, équilibrée).
Le confort est bof. Je n'aime pas ces écouteurs souvent trop petits, sans pour cela qu'ils doivent être proéminent. Il faut trouver le bon équilibre. Leur forme ne les rend pas si faciles à tenir dans 2 doigts quand on va vite et qu'on veut les manipuler.
Voilà, donc c'est bien mais sans plus.
Raymond B.
pour mini ordi GEEKOM
Fonctionne bien mais chauffe beaucoup: probablement le réchauffement climatique. J'espère qu'elle tiendra le coup longtemps
Gérard M.
SOMMERCABLE MERIDIAN SP215 Speaker Cable OFC Copper 2x1.5mm² Ø6.8mm This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen content ensure excellent acoustic...
Souple, facile à dénuder, se soude bien... Il ne dénature pas le son.
Donc, très bon câble. Je recommande.
Vicente P.
AUDIOPHONICS WIRE Speaker Cable Mogami 3103 Viborg Banana Plugs OFC Copper 2x 4mm² 3m (Pair) This speaker cable is assembled by us in the Audiophonics workshops. The choice of materials has been carefully considered and every detail and finish has been checked to offer...
La première insertion peut être très ferme
La première insertion peut être très ferme avec ce type de fiche banane à ressort. Il faut les insérer une première fois avec précaution, mais avec une certaine force, ou les comprimer très légèrement avant usage. Une fois cette première insertion effectuée, elles deviennent beaucoup plus faciles à brancher.
Jean-Louis L.
Joue remarquablement de la Musique
Acheté début Aout & mis en service, depuis une Source EVERSOLO DMP-A6, vers des KEF 105.2 recapées.
Cet Ampli LPA-450ET Purifi remplace avec Talent, un SANSUI AU-α 607 NRA II, trop difficilement réparable...
Je ne sais si un Rodage est nécessaire, mais il semble donner sa pleine mesure depuis 2~3 jours.
1er point : Spatialisation & impression d'un champ ~ espace plus vaste occupé par la musique.
2° : Basses légèrement plus fermes (Woofer B300~SP1071 neufs) et descendant peut-être plus bas encore.
3° : Neutre & sans véritable coloration.
4° : Borniers solides permettant un Large Câblage & une impression de solidité globale qui rassure.
5° : Ne chauffe presque rien, ce qui tend à valider l'excellent rendement électrique (surtout avec un Eté caniculaire).
Bref, il JOUE superbement la musique de fichiers Hi-Res, sans faire de cadeau aux enregistrements quelconques, avec Précision ~ Respect ~ Dynamique & Puissance (même si ce n'est pas ce que je recherche).
Les éloges de audiosciencereview.com et de qobuz.com semblent justifiées et je suis totalement satisfait de cet achat ;°)
Florian T.
Parfait pour Android
Je recommande chaudement ce dongle.
Je me suis équipé du récent Sennheiser HD480 Pro qui a une impédance de 130 Ohms (donc requiert un dongle pour être alimenté correctement), que j'utilise principalement avec mon smartphone et Apple Music en lossless.
Je l'utilise avec un câble symétrique jack 4.4 mm.
J'avais d'abord acheté le Fosi Audio DS2 sur Audiophonics également.
Premièrement, les boutons de volume ne fonctionnaient pas avec mon smartphone Nokia et j'entendais clairement une différence dans la maîtrise du grave lorsque je branchais le DS2 sur mon PC plutôt que sur mon smartphone : c'est comme s'il y avait un manque de courant lorsque je branchais le DS2 sur mon phone avec un manque de grave, ce qui n'arrivait pas lorsqu'il était branché sur mon PC.
Avec le Tanchjim Space, aucun problème !
D'une les boutons de volume fonctionnent et de deux, que je le branche sur mon téléphone ou sur mon PC, le grave est bien alimenté et maîtrisé dans les deux cas !
Je ne recommanderais pas le DS2 pour une utilisation Android...
mais je recommande volontiers le Space pour une utilisation smartphone/tablette/Android.
Iginio Roberto d.
AUDALYTIC DR70N DAC R2R Streamer Roon AirPlay UPnP Bluetooth 5.0 32bit 768kHz DSD512 Black The Audalytic DR70n is a high-end network DAC designed for demanding audiophiles, combining discrete R2R architecture, advanced network connectivity, and extensive compatibility...
audalytic dr 70n
rettifico in meglio la mia recensione precedente...anche in ottico è ottimale...era il mio cavo ottico che non andava bene
Jérôme T.
ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB White (Pair) The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter...
Excellentes
J'ai acheté ces enceintes sans les avoir entendus (je sais c'est mal) en me fiant à ce que j'ai pu lire dans audioscience, la confiance que j'ai en audiophonics, et puis ..je les trouve jolies.
Ma configuration :
- amplificateur audiophonics Tripath TA2022, préampli audiophonics,
- dac audiophonics Sabre ES9038Q2M muni d'une alimentation hifi ...audiophonics (bien sûr :-)
Au déballage, une belle impression de soin et de douceur s'en échappe.
Cette douceur se confirme à l'écoute.
Douceur, mais pas mollesse, car elles sont très dynamiques et particulièrement à l'aise sur les grands ensembles.
Depuis que je les ai reçues, j'ai pu parcourir presque toute ma discothèque qui est assez éclectique. De l’orchestre de chambre à l'électro, de la musique contemporaine à la world.
Dans tous les registres, elles sont impressionnantes de justesse et de clarté.
En conclusion, je n'ai jamais entendu des enceintes comparables à ce niveau de prix.
Elles sont vraiment excellentes.
Boris R.
Audiophonics-ap300-s250ncx : Le Graal ?
Cet amplificateur remplace un SMSL-AD18 dont l'alimentation venait de rendre l'âme. J'avais toujours comme ressenti avec une paire de Elipson P4I un manque d'assise dans les mediums. Apres un petit rodage, le son est apparu plus fidèle que jamais, bien présent dans les mediums, l'impact des bass était bien plus dynamique qu'auparavant .... bref cet ampli est incroyable, je regrette de pas l'avoir acheté bien plus tot ....
