Want to enjoy optimal headphone listening at home? Our range of sedentary headphone amplifiers is made for you. A wide selection of headphone amplifiers for both sensitive headphones and high-impedance models.
The FangSound Silenos is a small, versatile device that acts as a DAC, headphone amplifier, and preamplifier. Its digital-to-analog conversion stage consists of an R2R network of 192 complementary resistors to achieve clean rendering with sampling rates up to PCM 32-bit 768 kHz. Its amplification circuit is based on a balanced architecture that delivers...
Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the essence of your music. With very low distortion, impressive dynamics and an incredible level of detail, the OOR is the ultimate companion for headphone listening.
The Ferrum WANDLA HP combines the famous WANDLA DAC with a high-performance headphone amplifier. The latter incorporates the advantages of the WANDLA DAC, such as an ES9038PRO DAC chip and balanced architecture, enabling it to support high-resolution streams up to PCM 32bit 768kHz, DSD256 and MQA. On the headphone amplifier side, we find an IC amplifier...
The FiiO K11 is a versatile device that doubles as a USB DAC and headphone amplifier. KEY FEATURES :CS43198 DAC 32bit 384kHz DSD256 Powerful headphone amplifier: up to 14000mW on balanced output 3 gain levels Stable power supply: 16 low-noise LDOs FiiO logo LED display Various connectors: USB-C, Coaxial, Toslink, RCA, Jack 6.35/4.4mm
The FiiO K11 R2R, the R2R version of its cousin the K11, is a small, versatile and high-performance DAC headphone amplifier. It is based on a resistor network and audiophile components such as a GD32F303RET6 microcontroller, two TI OPA1642 OPAs, two MGM8262 amplifier chips and an R2R NJW1195A volume controller. The FiiO K11 R2R is therefore able to...
The FiiO K13 is a versatile device that acts as both a DAC and headphone amplifier. Digital-to-analogue conversion is handled by a balanced R2R resistor network, supporting files up to PCM up to 32bit 384kHz and DSD256. For its amplification stage, the K13 uses OPA1642 and TPA6120A chips in a balanced arrangement for a total output power of up to 2x2400mW...
The FiiO K15 is a versatile device that acts as a DAC, headphone amplifier and network audio player. Digital-to-analogue conversion is handled by a pair of AKM AK4497SVQ chips, supporting files up to PCM 32bit 768kHz and DSD512. For its amplification stage, the K15 uses a discrete Class AB architecture with MJE243G and MJE253G transistors to deliver an...
FiiO unveils one of its most sophisticated devices with its K19. The K19 is an ultra-complete, high-performance DAC/headphone amplifier. It features two ES9039MSPRO DAC chips for balanced signal processing and support for high-resolution PCM 32bit 768kHz and DSD512 streams. Two THX AAA-788+ modules handle signal amplification, for maximum output power of...
FiiO's K7 BT is a high performance desktop DAC and Headphone Amplifier combo, demonstrating an exemplary design for an audio reproduction marked by great transparency, richness and precision. It embeds a Bluetooth QCC5124 chip allowing the support of high definition formats, all with a low latency transmission.
FiiO's K7 is a high performance desktop DAC and Headphone Amplifier combo, demonstrating an exemplary design for an audio reproduction marked by great transparency, richness and precision.
FiiO offers us the evolution of their K9 model. The K9 AKM is a versatile DAC model integrating analog and digital inputs, and can be used in USB DAC mode. This model features a latest-generation AKM DAC coupled with its Delta-Sigma modulator, enabling music playback at resolutions of up to 32 bits / 768kHz and DSD512 file decoding. These two THX...
FiiO unveils an update to its K9 Pro, a 2x ES9038PRO DAC and headphone amplifier combo that uses only high-end audio components known for their sonic performance in a precision assembly. The K9 Pro features a dual high-end DAC, two THX-AAA 788+ amplifiers, dual femtosecond clocks, a QCC5124 Bluetooth receiver, an optimised power supply and fully balanced...
The FiiO R7 is the brand's first ever digital audio player featuring a high-performance ES9068AS DAC chip, two high-power THX-788+ headphone amplifier chipsets and a beautiful display for intuitive navigation. Featuring an extensive connectivity, the R7 can be used both as a standalone player and in combination with other devices.
With its R9, FiiO unveils an extremely versatile high-performance desktop device. The R9 functions as a DAC, network player and headphone amplifier. Two ES9038Pro DAC chips enable it to decode high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA, while its RJ45 port and large display give you easy access to all streaming services: Tidal,...
Compact, versatile and particularly affordable, the Fosi Audio DAC-Q4 brilliantly combines the functions of DAC and headphone amplifier. Ideal for a desktop installation, it will fit equally well into a more conventional audio system. Its digital/analog conversion stage is based on a Texas Instruments PCM5100 DAC chip, ensuring quality decoding for...
Compact, versatile and affordable, the Fosi Audio DAC-Q5 brilliantly takes on the role of DAC and headphone amplifier. Ideal for a desktop installation, it will fit just as well into a more traditional audio system. Its digital/analogue conversion stage is based on an ESS ES9018K2M DAC chip, ensuring high-quality decoding for rich, accurate sound...
Fosi Audio's GR40 is a versatile, compact stereo DAC and tube preamplifier, featuring full connectivity and Bluetooth 5.1. The digital-to-analog conversion section is based on an ESS9028Q2M DAC chip, and enables signal conversion up to PCM 32bit 384kHz and DSD256. Coupled with the tube preamplifier stage, the GR40 delivers the rich, warm sound...
The Fosi Audio GR70 is a headphone amplifier based on a combination of 2 x 564AW and 2 x 6AC7 tubes. As a result, it delivers a smooth, warm and authentic sound. Thanks to its LOW/HIGH gain control, it can drive headphones with impedances ranging from 16 ohms to 300 ohms.
With the K5 Pro, Fosi Audio offers a compact, versatile and affordable DAC/headphone amplifier. With its microphone input on the front panel, the K5 Pro is designed to fit into a desktop installation, although it can easily be integrated into a more conventional audio setup. Indeed, in addition to its headphone output, the K5 Pro has an RCA output, which...
The Fosi Audio K7 is a compact, high-performance DAC/headphone amplifier featuring an original design and high-quality components. It features an XMOS XU208 USB interface, an AKM AK4493SEQ DAC chip for its digital-to-analog conversion stage, and a balanced amplifier circuit with two TPA6120 chips and OPA1612 OPAs. The Fosi Audio K7 is therefore capable of...
The Fosi Audio MC331 is a powerful little hybrid integrated amplifier based on JAN5654W tubes and a TI TPA3221 chip. This little jewel blends modern and vintage technology, and is capable of delivering up to 2x105W of power under 4 ohm, enough to soundtrack a beautiful space.
The Fosi Audio P3 is a compact, high-performance preamplifier. It features two JAN 5654W tubes and a QCC3031 Bluetooth receiver chip. A 3.5mm jack is also available on the front panel, with volume and tone controls for bass and treble.
Fosi Audio's SK01 is a high-performance headphone amplifier with good measurements and low distortion. Its output power is up to 2400mW @ 32Ω. It also features numerous equalization potentiometers and two gain levels, enabling it to adapt to all types of headphones and in-ear monitors on the market.
With its SK02, Fosi Audio unveils a small, versatile, high-performance device that takes up the form factor of its SK01. The SK02 fulfills the functions of headphone amplifier, portable preamplifier and portable DAC. The SK02 features an ES9038Q2M DAC chip and a low-noise,...
The ZH3 from Fosi Audio is a preamp and headphone amplifier that also includes a DAC function. This versatile device is based on four OPA1612 chips to provide 2570 mW of amplification under 32 Ω per channel and uses an AKM AK4493SEQ DAC chip, allowing it to handle signals up to PCM 32-bit 768 kHz and DSD256. Its balanced circuitry, coupled with the...
Featuring an excellent 32-bit ES9038Q2M digital-to-analog conversion chip, the DAC FX-Audio D01 offers excellent audio performance with a wide dynamic range, low distortion, and jitter reduction. The USB interface uses a second-generation XMOS XU208 chip, supporting high sample rates up to 32bit 768kHz PCM and DSD512 with a custom Thesycon driver.
The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It features an innovative appearance and form factor, as well as quality components such as WIMA and Nichicon capacitors and a JRC NJW1194 volume control chip with output selector and tone control.
With its H26, Gustard unveils a class-A balanced audiophile preamplifier/headphone amplifier featuring discrete components. It features 8 pairs of power transistors, two dual LME49720 AOPs, two toroidal transformers, a relay volume control matrix and a balanced architecture.
In 2012, HIFIMAN unveiled the legendary EF6 DAC and headphone amplifier, offering a substantial energy reserve and a particularly detailed sound stage. Ten years later, HIFIMAN is back with a brand new model, the EF400, using all the best of the latest technologies developed and more particularly the brand's R2R Himalaya DAC module. The EF400 is a modern...
Hifiman's EF499 is a DAC and amplifier for headphones. It offers warm sound from R2R digital/analogue conversion and an output level of 4.35W at 32Ω, enabling it to drive a wide range of headphones. Its extensive connectivity makes it a highly flexible device, capable of fitting into a wide range of configurations.
An amazing format for an original, performing and practical product, the EF600 from HifiMan takes on the roles of balanced headphone amplifier, R2R DAC and headphone stand. Thus, in addition to offering a high quality headphone listening, it allows an obvious saving of space, ideal for an office installation.
The GA-10 is a HiFiMAN headphone amplifier developed in collaboration with GoldenWave. It uses ECC83/12AX7 tubes for its preamplification stage and EL84 tubes for its power stage. The use of these tubes results in a smooth, warm sound reproduction.
The HiFiMAN Mini Shangri-La amplifier has been specially designed to drive electrostatic headphones. Its amplification stage uses two MOSFET transistors (metal-oxide-semiconductor field-effect transistor) in a symmetrical design. Its independent high-voltage power supply stage is equipped with an independent power supply regulator, guaranteeing perfectly...
