Back
Amplifier chip
Class
Power (W)
30 - 950
Channel
Input
Output
Remote Control
Color
Categories
Brian C.
The rhodium plating makes it difficult to solder
I replace one of them on the back of my DAC... I think when my DAC was shipped to me maybe they had pressure pushing on them...
Remy M.
Simple et efficace
Matériel très propre, bien conçu, bien construit et abordable.
Idéal pour un système de bureau.
Il est positionné entre la...
Stephane c.
Excellente alimentation
Cette alimentation est robuste, très stable, avec un circuit imprimé solide qui permet de la retravailler si besoin....
Search by criteria There are 68 products.
  • Ref : 18908
    The Denafrips Thallo is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. This is an improved version of the brand's Hyperion model. The Thallo is capable of delivering 2x120W into 8Ω or 2x220W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped...
    2 639,00 € 2 199,17 €Ex.
    In Stock
  • Ref : 21928
    In Stock
    The Douk Audio NS-13G MAX is a compact stereo power amplifier featuring a built-in MM phono preamplifier, designed to efficiently drive a wide variety of passive speakers while allowing the direct connection of a turntable. Based on the TPA3255 amplification chip, it delivers up to 2x120W into 4Ω at THD+N=1%, ensuring powerful, dynamic, and...
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 21955
    In Stock
    The Douk Audio T6PRO is a hybrid HiFi amplifier combining tube amplification and modern Class D technology to deliver a sound reproduction that is both warm, dynamic, and powerful. It combines two JAN5725 tubes operating under a high voltage of 100V for true tube amplification with a high-end TPA3255 digital amplification chip capable of delivering up to...
    209,00 € 174,17 €Ex.
    In Stock
  • Ref : 21965
    In Stock
    In Stock
  • Ref : 20203
    In Stock
    Eversolo has designed the AMP-F10 class AB power amplifier to accompany its new streamer, the DMP-A10. This amplifier features a dual mono balanced architecture with no less than 5 MOSFET transistors per channel. This architecture gives it a substantial power reserve, as it is capable of developing up to 2x320W under 4 ohm and 2x200W under 8 ohm. Added to...
    2 590,00 € 2 158,33 €Ex.
    In Stock
  • Ref : 18515
    Reduced price!
    In Stock
    The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a result, it offers a high energy reserve, great dynamics and a highly accurate sound. The all-new SAPS switch-mode power supply provides the audio circuit with a clean electrical...
    690,00 € 575,00 €Ex.
    790,00 € In Stock
  • Ref : 21534
    Reduced price!
    The Fosi Audio CA30 is a power amplifier for car audio systems. Designed around the Infineon IR4322 amplifier chip, it delivers 4×100W under 4Ω, or 2×320W under 4Ω in bridged mode, using a high-efficiency architecture that delivers stable current while limiting internal heat build-up. This design results in a SINAD ≥ 80dB and...
    135,99 € 113,33 €Ex.
    159,99 € In Stock
  • Ref : 19171
    Reduced price!
    In Stock
    The Fosi Audio V3 MONO is a compact, powerful but still affordable 1-way amplifier. Based on a TI TPA3255 amplifier chip, it can deliver 240W at 4Ω. Furthermore, this amplifier is equipped with a host of audiophile components such as Japanese and German Elna and Wima capacitors, respectively, or a duo of DIP8-mounted TI NE5532 OPAs, giving you the...
    127,49 € 106,24 €Ex.
    149,99 € In Stock
  • Ref : 20935
    Reduced price!
    In Stock
    With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power supply noise reducer, a 48V 10A mains adaptor and a dual DC jack to power your two amplifiers.
    246,49 € 205,41 €Ex.
    289,99 € In Stock
  • Ref : 21849
    The LAiV Crescendo Chorus is an audiophile stereo power amplifier based on GaN (Gallium Nitride) technology, designed to deliver extremely transparent and dynamic sound reproduction in a compact format. Operating in GaN-optimized Class D, it uses ultra-fast switching GaN transistors combined with high-performance modulation and driver stages, resulting in...
    1 079,00 € 899,17 €Ex.
    In Stock
  • Ref : 21867
    In Stock
  • Ref : 20713
    LAiV Audio Harmony GaNM power amplifiers represent excellence in power amplification, coming in the form of two mono blocks exploiting gallium nitride (GaN) transistors for 200W of amplification at 8Ω per block, offering uncompromising sound quality. The meticulous attention paid to every aspect of the Harmony GaNM, from its ultra-low-noise power...
    5 639,00 € 4 699,17 €Ex.
    In Stock
  • Ref : 20711
    In Stock
  • Ref : 17504
    Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this family. Thanks to its highly efficient Class D architecture, it can easily be integrated into a system, providing significant power to your speakers.
    1 999,00 € 1 665,83 €Ex.
    In Stock
  • Ref : 21430
    With the AMP-8, MiniDSP presents an 8-source, 8-channel amplifier, enabling the creation of a complete multi-zone audio system. It is based on an ICEPower amplifier module capable of delivering 300W per channel under 4 ohms, while boasting an impressive signal-to-noise ratio of 123dB and a SINAD of 102dB. The amplifier module is complemented by an...
    2 890,00 € 2 408,33 €Ex.
    In Stock
  • Ref : 19750
    In Stock
    The Singxer SA-90 class A/B mono power amplifier delivers ultra-low-noise, ultra-low-distortion performance while offering no less than 200W output power at 4 ohms. Like most power amplifiers on the market, it adopts a monoblock design with a simple, minimalist look.
    699,00 € 582,50 €Ex.
    In Stock
  • Ref : 20393
    SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume control and in mono as a pure power amplifier, and relies on Infineon GaN FET transistors. It offers up to 2x160W under 4 Ohm power via its stereo RCA input, and up to 1x400W under 4...
    449,00 € 374,17 €Ex.
    In Stock
  • Ref : 18657
    Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device,...
    3 590,00 € 2 991,67 €Ex.
    In Stock
  • Ref : 17768
    In Stock
    In Stock
  • Ref : 17769
    In Stock
    With the AD-2500 Pro, Tonewinner offers a particularly powerful stereo Class AB power amplifier. This one is indeed able to develop a power of 2x950W under 4Ω while offering a great dynamic range and ensuring a low noise level for a sound reproduction as precise as musical.
    1 790,00 € 1 491,67 €Ex.
    In Stock
  • Ref : 17346
    In Stock
    The Tonewinner AD-5100PA+ is a Class AB power amplifier featuring 5 channels capable of delivering 130W into 4Ω or 90W into 8Ω each. It is therefore an ideal model for integration into a home theater system. It uses 5 pairs of Toshiba TTC5200 and TTA1943 transistors, ensuring a musical and rich sound reproduction. The low-noise differential...
    629,00 € 524,17 €Ex.
    In Stock
  • Ref : 17354
    In Stock
    The Tonewinner AD-7300PA+ is a 7-channel Class AB power amplifier, ideal for home theater integration. Capable of developing significant power, measured at 584W RMS for one channel powered at 4Ω or 7x190W for 7 channels powered at 8Ω, this amplifier offers great dynamics and ensures low noise.
    2 090,00 € 1 741,67 €Ex.
    In Stock
  • Ref : 17407
    In Stock
    Tonewinner presents its AD-8300PA, an 11-channel power amplifier, allowing a home cinema integration, including Dolby Atmos systems. It delivers a consistent power with low distortion for an immersive and dynamic sound reproduction. Coupled with an audio/video preamplifier (sold separately), the AD-8300PA is an excellent solution for entering the world of...
    In Stock
  • Ref : 19759
    In Stock
    The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's proprietary amplifier module to deliver 100W of power at 4 ohms, while maintaining a THD+N < 1% and a DNR of 151dB.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 19764
    Out of stock
    Out of stock
  • Ref : 19588
    In Stock
    The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms.
    599,00 € 499,17 €Ex.
    In Stock
  • Ref : 19586
    In Stock
    In Stock
  • Ref : 21843
    In Stock
    The Topping Hynotone Cabscreamer60 is a guitar power amplifier in pedal format, designed to complement a pedalboard or a system based on a preamp / multi-effects unit. It delivers 60W of power at 4 ohms (1% THD), allowing it to directly drive a guitar cabinet while maintaining an ultra-compact form factor.
    129,00 € 107,50 €Ex.
    In Stock
