DIY Kits & Boards
Francis F.
Câble SEATHL SC-221 OCC
En remplacement du Magami 2549 entre mon Ladder Bach 2 et mon Ampli de cœur Grand Mos .
Sur mon système le timbre...
Mario J.
No brainer
If you need this type of phones, this is a no-brainer. Its feather lite, sound really good, just add bass below 100Hz. I use...
Francisco R.
It's a Cable
It's a cable, what can I say. Cables don't have a sound.
Anyway, Audiophonics is a fantastic store. Fast delivery,...
DIY Kits & Boards
DIY Kits & Boards
  • DAC Modules
    DAC Modules
  • Amplifier Boards
    Amplifier Boards
    Amplifier Boards
  • Preamplifier modules
  • Headphone amplifier modules
  • Switching Module
    Switching Module
  • Interface Modules
    Interface Modules
  • Subwoofer Modules
    Subwoofer Modules
  • Power Supply Kits
    Power Supply Kits
  • DSP Modules
    DSP Modules
  • Screens / Vu-meters
    Screens / Vu-meters
  • Softstart & Protection
  • PC / HTPC Modules
    PC / HTPC Modules
  • Streamer Modules
    Streamer Modules
