Back
Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
100 - 110
Channel
Input
Output
Remote Control
Networking
Streaming services
Color
Categories
Lionel B.
Ampli livré 2 semaines après la commande, comme annoncé. Très bon matériel. Le boitier est bien fini et compact. L'ampli...
Bruno L.
Superbes!
A mon avis et dans mon cas d’usage il sont excellents et supérieurs aux MUNDORF SUPREME SILVERGOLD OIL que j’utilisai jusqu’à...
Zean V.
Bon produit - logistique à améliorer
Bon produit pour la calibration avec REW.
Réception après 8 jours (lent quand on à l'habitude d'Amazon)
Le suivi...
Search by criteria There are 72 products.
  • Ref : 21860
    The Shanling EC Play is a portable CD player designed to take the enjoyment of physical media beyond fixed installations. Weighing 418 g and offering up to 12 hours of battery life, it features an active magnetic drive mechanism coupled with Shanling’s proprietary servo system, ensuring rotational stability and playback accuracy comparable to those...
    189,00 € 157,50 €Ex.
    In Stock
  • Ref : 21858
    In Stock
    In Stock
  • Ref : 19858
    In Stock
    The Shanling EC Smart is an affordable, high-performance CD player with an atypical, resolutely modern design. With its vertical format, the EC Smart accommodates CDs just behind its control panel, which can be rotated. Everything is designed to be extremely easy to use, with no need for complicated settings or adjustments.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 22356
    In Stock
    The Shanling EC ZERO T MAX is a portable battery-powered audiophile CD player that also functions as a high-resolution USB DAC and Bluetooth 5.3 transmitter.
    689,00 € 574,17 €Ex.
    In Stock
  • Ref : 17957
    In Stock
    The Shanling ET3 is a complete, powerful CD player with a modern design and excellent sound performance. Versatile, it offers full connectors and wireless connectivity, enabling it to be integrated into many audio systems, providing a high-quality source. It can even be used as a file player and NAS, thanks to a USB input for storage devices, combined...
    699,00 € 582,50 €Ex.
    In Stock
  • Ref : 22426
    The Shanling ET3 EVO is a top-loading digital CD transport designed to play discs, Hi-Res files and network streams before sending the signal to an external DAC. Its Ingenic X2000 platform, its upsampling system and its USB and I2S outputs allow conversion up to PCM 32bit / 768kHz and DSD512, while the AES/EBU, coaxial and optical outputs provide broad...
    649,00 € 540,83 €Ex.
    In Stock
  • Ref : 19368
    Reduced price!
    In Stock
    Shanling's MCD 1.3 is a top-of-the-range CD player with an XMOS XU316 USB interface, AK4499EX+ AK4191EQ DAC chip combo, TPA6120 headphone amplification and MUSES8920 line-out pre-amplification. This device is extremely versatile, thanks in particular to its multiple connections coupled with Bluetooth 5.0 and WiFi functionality supporting DLNA and Airplay...
    849,15 € 707,63 €Ex.
    999,00 € In Stock
  • Ref : 19370
    Reduced price!
    In Stock
    999,00 € In Stock
  • Ref : 20661
    Reduced price!
    In Stock
    With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a striking aluminium chassis, it is equipped with Sanyo DH870 laser optics and is capable of reading CD, SACD and MQA CDs.
    1 679,00 € 1 399,16 €Ex.
    1 949,00 € In Stock
  • Ref : 21557
    The Shanling SCD3.3 is an SACD and CD-MQA compatible CD player featuring a third-generation discrete R2R conversion architecture developed in-house. It uses a 2R2 network totalling 212 resistors matched to 0.01%, spread across four channels to provide 24-bit conversion.
    3 839,00 € 3 199,17 €Ex.
    In Stock
  • Ref : 21584
    The SMSL PL100 Pro, an evolution of the PL100, is a CD player now based on two CS43131 DAC chips combined with a PLL (Phase-Locked Loop) circuit to provide sound reproduction as close as possible to the original source. The unit supports several CD formats: CD / CD-R / CD-RW / MP3 CD.
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 21587
    In Stock
  • Ref : 20923
    The SMSL PL150 is a CD player based on a CS43198 DAC chip, a proprietary mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
    In Stock
  • Ref : 20924
    In Stock
    In Stock
  • Ref : 21347
    In Stock
    The SMSL PL20 is positioned as a versatile CD player combining a dual CS43131 DAC architecture with a built-in ripper function, while ensuring DSD compatibility for high-resolution formats. This technical foundation is accompanied by extensive connectivity, from bidirectional Bluetooth to USB playback of DSD64 files, complemented by two dedicated...
    207,90 € 173,25 €Ex.
    In Stock
  • Ref : 21354
    In Stock
    In Stock
  • Ref : 22239
    In Stock
    The SMSL PL200 MK2 is an audiophile CD player that also functions as a USB DAC, digital interface, headphone amplifier, and bidirectional Bluetooth transmitter/receiver.
    619,00 € 515,83 €Ex.
    In Stock
  • Ref : 20546
    The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS USB interface on a USB-C connector. The playback system natively supports MQA CD and USB interface up to PCM 32bit 768kHz, DSD512 and MQA.
    549,00 € 457,50 €Ex.
    In Stock
  • Ref : 19478
    In Stock
    The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features an optimized clock system. It is equipped with a P.A.S.S (Precison Access Servo System) playback system that natively supports MQA-CD. The SMSL VMV T2 also supports high-resolution PCM 32bit 768kHz and DSD512 streams, as...
    949,00 € 790,83 €Ex.
    In Stock
  • Ref : 17514
    In Stock
    The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD collection at home as well as on the road. It also features Bluetooth 5.3 transmission capability, allowing it to automatically pair with Bluetooth headphones or speakers.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 17034
    In Stock
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 21048
    In Stock
    The Syitren R400 is a small battery-powered CD player that combines retro design with modern features. It is equipped with an M93BG6 playback head and an SC6137D decoding chip. In terms of functions, the R400 offers a choice of playback modes: loop, single loop, or random. In addition, in terms of connectivity, it features a classic 3.5mm jack output for...
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 22614
    The Styitren RM1 is a portable CD player with a transparent chassis, designed to make its internal circuits visible while playing CDs. Its custom mechanism, combined with three-point silicone damping and electronic anti-skip protection, contributes to steady playback.
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 22244
    In Stock
    The Thinkya DVP‑560 is a compact CD player with integrated amplification, designed to ensure stable disc playback while extending listening possibilities to external and wireless sources. It leverages optimized read mechanics with anti-jitter system, coupled with Toslink optical output and bidirectional Bluetooth 5.1 transmission, thereby guaranteeing...
    75,90 € 63,25 €Ex.
    In Stock
  • Ref : 20932
    In Stock
    Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM 768kHz and DSD512. The DRV108 also benefits from Bluetooth 5.1 bi-directional connectivity, allowing you to enjoy the convenience of a wireless connection, whatever your system...
    229,00 € 190,83 €Ex.
    In Stock
  • Ref : 18020
    The Thinkya JA-310 is a compact, attractive CD player that also acts as a USB file player. With its blend of vintage and modern aesthetics, it is both an excellent audio device and a beautiful decorative object, which will blend effortlessly into any living room.
    59,91 € 49,92 €Ex.
    In Stock
  • Ref : 22240
    In Stock
    The Thinkya K10 is a compact CD player integrating digital conversion and amplification, designed to ensure stable disc playback while expanding usage to dematerialized sources. It leverages optimized read mechanics with anti-jitter system, coupled with hybrid connectivity including optical output and bidirectional Bluetooth 5.1, thereby guaranteeing...
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 22105
    In Stock
    The Thinkya R02 is a compact CD player with integrated amplification designed for autonomous and versatile use, combining optical playback and wireless transmission. It relies on an integrated architecture pairing dual 2 x 1.5W stereo speakers with bidirectional Bluetooth 5.0 connectivity, enabling both direct reproduction and signal transmission to...
    119,00 € 99,17 €Ex.
    In Stock
  • Ref : 19941
    Reduced price!
    In Stock
    The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as OPA1632 AOPs and an enhanced playback system, all incorporated in an anti-vibration chassis for optimum sound reproduction of your favorite CDs. It supports a wide range of formats...
    999,00 € 832,50 €Ex.
    1 190,00 € In Stock
  • Ref : 17351
    Reduced price!
    In Stock
    The Tonewinner TY-30 is a beautifully integrated CD player, based on the use of quality components for efficient CD playback. The chassis is perfectly damped in order to limit considerably the vibrations that could affect the playback and its stability.
    629,00 € 524,17 €Ex.
    699,00 € In Stock
  • Ref : 22500
    The Trettitre TTT-DP3 is a portable CD player featuring Bluetooth 5.4 transmission, designed to combine physical media playback with wireless audio integration. Compatible with CD, CD-R and CD-RW discs, it relies on a compact design with a transparent magnetic lid, revealing the disc while making everyday use easier.
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 22067
    In Stock
    The xDuoo CDM10 is a portable audiophile CD player that also features a high-resolution USB DAC function. Designed around a fully balanced architecture, it incorporates two Cirrus Logic CS43198 digital-to-analog converters paired with a dual Raytheon JAN6418 tube output stage, allowing instant switching between a neutral and detailed solid-state sound...
    469,00 € 390,83 €Ex.
    In Stock
