Intégrité de la source réduction du jitter Utiliser sur deux parfums différents: SMSL(akm) et Audio-gd(wm8741) pour le casque. L'étage en terme de gain est tout...
Câbles remarquables. Branchés sur mon Drive CD Atoll 400 SE, les détails et la précision des timbres sont remarquables. Câbles étonnants, à brancher...
The Neotech NEI-3002G is a balanced interconnect cable utilising two G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor represents a significant breakthrough, both in terms of research and industrial applications. Indeed, the addition of graphene improves the stability of electrical signal transmission at high...
The Keces P9 is a low-noise regulated linear power supply, a direct successor to the P8, designed to provide stable, clean power to sensitive audio components. It delivers up to 5A per rail, with a peak capacity of 7A, utilising an in-house developed toroidal transformer, whose precise winding and carefully selected materials stabilise the voltage whilst...
The Dayton Audio Classic B40 bookshelf speakers are passive speakers featuring a 10.16cm woofer and a 2.54cm silk dome tweeter, able to support up to 30W RMS power at a 6-ohm load (60W max.). They have the advantage of being able to be placed anywhere and are ideal for near-field listening.
The Keces Ewave is a network switch designed for the most demanding systems. It features eight 10/100/1000 Mbps-compatible ports and is based on an in-house circuit design, with routing and layout optimised to minimise electromagnetic interference (EMI/RFI) and ensure consistent data transmission.
The Fosi Audio BT20A PRO is a compact and powerful Class D amplifier, offered at a very resonable price. Its amplifier stage uses a TI TPA3255 chips, capable of developing a power of 225W under 4Ω per channel.
The Fosi Audio TP-02 is a compact and efficient Class D subwoofer amplifier. It features a TDA7498E amplifier chip, enabling it to deliver 220W of power into a 2Ω load, as well as a NE5532 operational amplifier. It can be used with either an active or passive subwoofer, and its low-pass filter allows it to handle frequencies ranging from 20Hz to...
The FiiO M33 R2R is an audiophile portable music player based on discrete R2R conversion, designed to play and process high-resolution audio streams in both portable and stationary settings. It delivers 2x 1100mW into 32Ω, utilising a balanced architecture and a network of resistors calibrated to 0.1% to ensure stable conversion and consistent...
The Fosi Audio BT20A MAX is a Class D stereo amplifier designed to power passive speakers with a high level of control and power in a compact format. It delivers up to 2x85W under 4 Ohm with 32V power supply (or 2x180W under 4 Ohm with 48V power supply), relying on a PFFB (Post Filter Feedback) architecture and a segmented power supply to maintain low...
The iBasso DX270 R2R Ultra is a high-end audiophile digital audio player (DAP) designed to deliver outstanding sound performance on the go. It features a unique conversion architecture combining a 20-bit R2R + 4-bit String hybrid DAC, integrated into a fully differential 8-channel configuration, supported by an FPGA-Master 3.0 controller and ultra-precise...
The PURIFI PTT8.0X04-NAB-02 is an 8-inch (20.32 cm) loudspeaker with a nominal impedance of 8Ω, designed to deliver accurate midrange reproduction whilst maintaining a usable extension in the bass and treble ranges. With a power handling capacity of 300W and extremely low distortion, even at full power, the PTT8.0X04-NAB-02 is the ideal choice of...
The Moondrop Moonriver 3 is a portable USB DAC / headphone amplifier designed to deliver very high-fidelity audio reproduction on the go. As the successor to the Moonriver series, it features an advanced architecture combining dual Cirrus Logic CS43198 DACs, independent amplification stages, as well as an optimized power circuit based on 5 dedicated power...
The iFi Audio iEMatch+ is a passive impedance adapter cable designed to be connected between a source (smartphone, DAP) and earbuds or headphones to reduce impedance and background noise. It offers an output impedance of less than 2.5Ω or 1Ω, helping to minimize response variations associated with sensitive earbuds while maintaining linear...
The ZiiGaat Z-01 is a high-end cable designed for in-ear monitors (IEMs), featuring a 5N single-crystal copper construction. This cable stands out for its LITZ Type 1 construction, which minimizes signal loss and reduces impedance to just 0.4592 Ω, resulting in natural, detailed, and balanced sound reproduction.
The SMSL PS200 PRO is a compact and versatile DAC, designed to deliver exceptional sound quality at an affordable price. Equipped with the latest-generation ES9039Q2M DAC chip and the XMOS XU316 USB processor, this DAC supports high-resolution audio formats up to 32-bit/768kHz PCM and DSD512, as well as MQA and MQA-CD decoding. Its ultra-lightweight...
The Wondom PS-BC12114 BCPB0 1S is a highly efficient and reliable charging and protection module, specifically designed for 26650 Lithium batteries. Featuring a 5V boost circuit, it allows the battery to be used as a power bank to charge mobile devices, Raspberry Pis, or other USB devices.
The iFi Audio UP Travel is a portable Bluetooth receiver-transmitter designed to add wireless functionality to devices that do not have it built-in. It delivers 70mW of output power at 32Ω, utilizing a multi-stage architecture (DAC, amplifier, and Bluetooth module) to minimize internal interference and maintain signal stability during mobile use.
The FiiO K17 is a high-end DAC and headphone amplifier designed to deliver a comprehensive and versatile audio experience, whether for audiophiles or users looking for an all-in-one device for their home office or living room. It stands out for its balanced architecture, high amplification power, and extensive connectivity, making it a top choice in its...
The Ugreen BT505 is a Bluetooth 6.0 receiver designed for wireless audio playback from mobile devices, featuring LDAC compatibility to transmit high-resolution audio. This extends the frequency response from 20 Hz to 40 kHz, covering the entire audible spectrum and beyond under suitable conditions. The unit is powered by a 300 mAh battery offering up to...
The xDuoo Link3 is a portable headphone amplifier DAC featuring a dual ES9039Q2M architecture, designed to convert and amplify high-resolution audio signals on the go. It supports streams up to 32bit 768kHz PCM and DSD512, utilising a 16-core XMOS XU316 USB interface to ensure stable, low-latency transmission, resulting in accurate reproduction with a...
The Aune S18 EVO is a DAC designed to ensure accurate reproduction of digital audio streams, utilising a dual-chip AK4497 architecture combined with global clock synchronisation. It achieves a distortion level of -116 dB and an output noise of 2.6 µV, utilising centralised clock management via PLL to stabilise the timing signal prior to conversion.
The SMSL DL400 is a DAC and headphone amplifier designed to deliver very high-level audio performance in a compact form factor. Thanks to high-quality components such as an ESS ES9039MSPRO DAC chip, as well as a balanced headphone amplification architecture featuring a PLFC (Precision Linear Feedback Circuit), impressive headphone amplification power, and...
The FiiO JA11 is a portable USB DAC designed to handle digital-to-analogue conversion using a compact architecture capable of processing high-resolution audio streams up to 32-bit/384 kHz PCM and DSD128.
The FiiO AIR LINK is a small, portable, and convenient USB Bluetooth transmitter that allows for simultaneous charging and audio streaming. It features a Qualcomm QCC5181 chip and Bluetooth 6.0 technology, enabling the AIR LINK to provide a stable, fast, and virtually latency-free connection. The AIR LINK features a USB-C input and output, making it easy...
The iFi Audio GO Blu Air is a portable Bluetooth DAC and headphone amplifier designed to follow you everywhere. Both practical and high-performance, it features a magnetic clip for easy transport on the go. Powered by its Qualcomm QCC5144 chip dedicated to Bluetooth 5.2, the Go Blu Air offers high-performance audio reception, thanks in particular to its...
The M23 PRO is a Bluetooth 6.0 receiver/transmitter designed to provide two-way audio transmission within a hi-fi system. It utilises a dedicated dual-chip architecture – one chip for reception and the other for transmission – to manage incoming and outgoing audio streams simultaneously, whilst its OLED display allows playback information to...
This affordable Class D amplifier is based on a TPA3251D2 amplification chip, delivering 2x140W at 4Ω with high efficiency. It will therefore have no difficulty driving most speaker models. In addition, it benefits from PurePath Ultra HD technology, maintaining a very low distortion level across the entire frequency range while offering excellent sound...
The power cable Pangea AC-14 is specifically designed for source components, which do not require the same current levels as receivers and amplifiers. The AC-14 delivers more current while offering multiple layers of shielding and other features that ensure extremely clean and noise-free power to your equipment.
The Ayino MR265PRO is a Bluetooth 5.0 transceiver designed to enable two-way audio transmission between wired sources and wireless devices, utilising a Qualcomm CSR8675 chip to support SBC, AAC and aptX codecs in both their HD and Low Latency variants.
The Ampapa / Douk Audio 6.35mm TRS to XLR female cable is a high-quality balanced audio cable designed to ensure perfectly clean and distortion-free signal transmission. It allows efficient connection of HiFi or studio equipment such as DACs, amplifiers, audio interfaces or active speakers thanks to its 6.35mm TRS male jack to 3-pin XLR female connectivity.
The Ampapa 6.35mm TRS jack interconnect cable is a HiFi balanced audio cable designed to ensure perfectly stable, clean, and interference-free signal transmission. It is suitable for audiophiles, studio users, and content creators looking to get the most out of their audio equipment.
The AMPAPA BK1 is a desktop HiFi stand designed to organize and showcase your compact audio electronics. Designed to perfectly accommodate devices from the Ampapa range (A1, D1, Q1), it provides an elegant, robust, and functional solution for building a cohesive and high-performance HiFi system.
The FiiO M21 is a stylish Hi-Res portable audio player (DAP) that delivers excellent audio performance. Powered by an 8-core Snapdragon 680 SoC and running Android 13, it ensures fast processing speeds and a smooth user experience, while offering broad compatibility with services such as Tidal, Qobuz, Apple Music, Spotify, and Deezer.
The Ampapa Q1 is a high-performance desktop DAC / headphone amplifier designed for audiophiles seeking versatility, precision, and sound customization. It features a dual DAC architecture combining ESS9039Q2M and AK4493 chips, paired with an XMOS XU316 USB interface for high-resolution audio processing up to PCM 768kHz 32bit and DSD512.
The Douk Audio M1 MAX is a compact Class D stereo amplifier designed to efficiently drive a wide range of passive speakers. It is based on the TPA3255 chip, known for its excellent efficiency and low distortion, allowing it to reach a maximum power of up to 2x250W depending on the power supply used. It is supplied here with a 48V 5A power supply...
With the M3 Plus, Shanling presents a high-definition digital music player, the direct successor to the M3 Ultra, featuring an improved analogue/digital conversion stage, greater output power and an operating system updated to Android 13.
The FiiO KA11 is a portable DAC based on a CS43131 DAC chip for digital-to-analog conversion, along with SGM8262 operational amplifiers to amplify the signal. This compact portable DAC supports high-resolution streams up to PCM 32bit 384kHz and DSD256, and is capable of delivering up to 2x 245mW into 16 ohms.
The FiiO KA11 is a portable DAC based on a CS43131 DAC chip for digital-to-analog conversion, along with SGM8262 operational amplifiers to amplify the signal. This compact portable DAC supports high-resolution streams up to PCM 32bit 384kHz and DSD256, and is capable of delivering up to 2x 245mW @ 16 ohms.
The Furutech FT-SWS-NCF PLUS (R) is a Schuko wall socket that represents a direct evolution of the FT-SWS-NCF model, retaining its fundamental principles whilst enhancing its mechanical and electrical capabilities. It retains the architecture based on cryogenically treated and demagnetised α (Alpha) copper conductors, to which a non-magnetic rhodium...
